Fumes
Old Jun 14, 2006 | 06:39 PM
88droptopgt's Avatar
88droptopgt
Default Fumes
Ok folks. I have gas fumes coming from the motor area. This is unburnt gas, fresh gas fumes. You smell it the worst when you have the HVAC going. I have no gas leaks, not nothing of that type. Nothing on motor, noting under car anywhere. Is there a canister somewhere that vents or the like that needs to be replaced??
Old Jun 15, 2006 | 01:10 AM
anthonydalrymple's Avatar
anthonydalrymple
Default RE: Fumes
Odds are the fuel vacuum control solinoid(might not be the proper term), mounted right above the charcoal canister, that has failed. It if does not open when the car is shut off like it should; it does not allow excess fuel to return to the fuel tank. The cannister itself could be bad; I'd inspect it for damage due to possible debris being kicked up from the road. You should pull KOEO codes; there is a code for that specific solinoid not functioning....IMHO
Old Jun 15, 2006 | 12:41 PM
88droptopgt
Default RE: Fumes
Where is the canister and this silenoid located? The car did get hit on pass front side.
Old Jun 15, 2006 | 06:14 PM
anthonydalrymple
Default RE: Fumes
ORIGINAL: 95plainjane
Lower front, passenger side, attached to the frame rail. If you have either a Chilton's or Hayes repair manual from a local parts store; you can see drawings of it. It'll show the solinoid, line routing, etc. The manual will pay for itself very quickly IMHO.....
Scottyboy187
SVT Forums
Nov 20, 2015 02:57 PM
Scottyboy187
Nov 5, 2015 04:18 PM
fordguy17
Feb 24, 2007 04:06 PM
Dubs1
Mar 9, 2006 02:14 AM
jaynez31
Feb 9, 2006 11:43 AM
