331
Old Jun 22, 2006 | 01:46 AM
Mthd11's Avatar
Mthd11
Default 331
Can you bore out a 302 to a 331, or is a 306 the most you can go on a 302 block? Im assuming you have to get a new block and a stroker kit for the 331 correct? and by a new block i mean a 331 block. could you slap on a 302 lower/upper intake and have it fuel injected or is it carb only? do they make fuel injection for the 331?
By the looks of it 331's make a hell of a lotta hp. but you dont see alot of them, is it because theyre less reliable or 347s and 351s are just more popular and bigger lol.. go on streetfire and search 331, they look and sound pretty badass...
Old Jun 22, 2006 | 01:56 AM
frop's Avatar
frop
Default RE: 331
331s are only strokers in a stock block. 347s are what's hot, & 16 more c.i. Almost any SB Ford combo can be carbed or FI in any number of ways. 331s don't have a specific block, it's a standard 302 block.
Old Jun 22, 2006 | 02:38 AM
gspfunk's Avatar
gspfunk
Default RE: 331
302=4.000" bore x 3.00" stroke (stock 5.0)
306=4.030" bore x 3.00" stroke (bored over .030"--helps clean up cylinder walls on a rebuild)
331=4.030" bore x 3.25" stroke (327 if bore is stock)
347=4.030" bore x 3.40" stroke (342 if bore is stock)
The 331 has a rod ratio close to that of a 302, making it more reliable. The 347 has a smaller rod ratio which tends to make it a shorter lived motor. That doesn't mean it's going to blow at 10k, just that they don't usually last as long as a 302 or 331.
If you have a 5.0, you would use your stock setup for whichever motor. You might need to upgrade injectors and some other things, but you'd retain your stock wiring, computer, etc.
Old Jun 22, 2006 | 04:18 PM
Mthd11's Avatar
Mthd11
Default RE: 331
for some reason 331's appeal more to me than the 347s and 351's the videos on street fire make me drool...
and boring it out to 331 wouldnt bring it to close to the water jackets?
edit: i found a good article on a 331 build. http://www.mustangandfords.com/techarticles/5197/
Old Jun 23, 2006 | 05:01 PM
gspfunk's Avatar
gspfunk
Default RE: 331
No, it's only bored over .030...just don't go more than that on a stock block
Old Jun 24, 2006 | 10:41 PM
tinman's Avatar
tinman
Default RE: 331
Don't worry about the rod ratio/lenght thing and just build the 347..
I concur about not ever trying to bore the stock block past .030...
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
MonsterBilly
Aug 12, 2015 12:01 PM
fiveohfox
Feb 23, 2005 01:40 AM
DukeU03
Oct 5, 2004 12:20 AM
Allen
Jul 26, 2003 05:35 PM
