Auto trans: Leave it in D or N while waiting at a stop light?
Old May 2, 2004 | 12:46 PM
vfast's Avatar
vfast
I ♥ Acer
Default RE: Auto trans: Leave it in D or N while waiting at a stop light?
*L* are they for real?....leave it in drive your drive train will thank you for this
Old May 2, 2004 | 04:04 PM
jeep45238's Avatar
jeep45238
I ♥ Acer
ORIGINAL: propellerhead
Let me explain...
I was just reading up on stall converters yesterday and while I was at a long stoplight this afternoon, I was thinking about the engine idling and the flywheel spinning, yet I'm holding down the brake pedal and there's no forward motion. The torque converter is operating below the stall speed so there's very little torque transfered to the driveshaft. All this time, there's a slight load on the engine because the transmission is in gear but the energy is simply wasted as it is converted into heat in the torque converter.
But if I pop the transmission into neutral, the load is removed from the engine and it idles freely. Isn't this less strain on the transmission? Doesn't this mean the liquid coupling is not actively allowing the slip? It's just doing nothing? Isn't it less strain on the engine too? If so, then wouldn't it be better to shift into neutral at long stoplights?
Tranny experts, can you fill in?
The tranny was designed to have this happen to it, leave it be. Besides, sooner or later you'll accidently slam it, or you're gonna have some pissed off wack behind you because you're not going when the light's moving.
Old May 2, 2004 | 06:51 PM
fantasyfords's Avatar
fantasyfords
I have caught myself lately putting my car in park when at a long light. I just put new brake pads on my car about amonth ago and I noticed I was getting crazy brake fade after a few hard stops. I started thinking about it and if you sit at a light ( in an auto) in drive all you are doing is keeping all that heat on your front brakes. Now I sometimes use park and believe it or not but my brake fade problem has gone away.
Old May 2, 2004 | 11:07 PM
vfast's Avatar
vfast
I ♥ Acer
it may help a slight bit but at a light there is NO friction going on and no more heat build up..try a dot 4 or 5 fluid and some good pads
Old May 4, 2004 | 04:40 PM
SilverGTV8's Avatar
SilverGTV8
when you are coming to a stop with the auto, release a little pressure off the brake. You don't need as much pressure to stay stopped as you do to stop the car. I drive a stick, and I usually brake hard until about 5mph and then let up on the brakes and roll slowly into the stop, using the brakes just enough. That helps disapate the heat and gases. If you are suffering from major brake fade, it could be fluid, but usually the culprits are improper break in and poor pad choice.
Most people when they put on brakes they go out and stomp on the peddle to see how well it stops. Not what you should be doing. You should be stopping from 20mph with moderate break pressure, letting the brakes cool some, stopping at 30 the same way, on and on to 60mph, making sure to give enough time for the brakes to cool. After that has been done, go fill up the gas tank on the car. Stop with moderate to mild pressure, until the tank is empty. Now you can go a stand on them and brake fade should be almost non-existant for a little longer.
jpplaw
Mar 19, 2025 08:53 AM
Nurdyguy
Jan 20, 2025 04:38 PM
djbigskrilla
Sep 20, 2022 01:04 AM
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
UINZWAY
S197 Shelby Section
Aug 5, 2015 10:34 PM
