maf worth it?
Old May 4, 2004 | 12:12 AM
fast86gt's Avatar
fast86gt
Default maf worth it?
i have an 86 gt w/o maf, would it be worth the few hundred bucks to upgrade? what would be the benefeits?
Old May 4, 2004 | 02:42 AM
VertStangGT86's Avatar
VertStangGT86
Default RE: maf worth it?
It's more accurate then the speed density and will help you run a little smoother. I've always had it so I can't give you a before and after but I doubt people would bother doing it if it didn't help.
Old May 4, 2004 | 03:15 AM
2000GT4.6's Avatar
2000GT4.6
Only if you plan on modding it further. There are other things you could do first that would be better for you, assuming you havent already done em (aka gears, exuast, etc).
The MAF change allows you to fully optimise your modifications. However on a stock car I doubt you will see a significant gain.
I guess the real question is, how much is it? If its dirt cheap, go for it. That way everything you do from now on will have a better effect. However if its expensive and going to be your only mod, its not worth it.
Old May 7, 2004 | 02:12 AM
VertStangGT86
I think it's between two and three hundred for the conversion kit. I'd get some more stuff done on your motor first then go for it.
jwog666
Dec 27, 2021 08:09 PM
piotrek53
Oct 13, 2015 06:54 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
treesloth
Sep 28, 2015 07:03 AM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
