Should I change weight?
Old May 4, 2004 | 12:29 PM
SilverGTV8's Avatar
SilverGTV8
Default Should I change weight?
Hey everyone,
I am currently running Royal Purple 5-20 in my car. I am wondering if I should change to 10-30 before the car is use the weight of the 5-20. I plan on making power and I am concerned with the extra heat letting the oil get to thin.
The car will have 20,000 by the time I need to change it again, and would like to start it on 10-30 if that would be better then the 5-20. I don't care about mileage, but about keeping the motor safe as possible.
Old May 4, 2004 | 05:11 PM
VertStangGT86's Avatar
VertStangGT86
Default RE: Should I change weight?
The times I've seen people use 5-20 have been on higher milage engines, don't think you really need to run it in yours.
Old May 4, 2004 | 05:40 PM
Monch's Avatar
Monch
change to 5-30 if you're concerned about extra protection. 10-30 is a bit too thick when you turn the car on in the morning. But if royal purple doesn't make 5-30 then 10-30 would work.
Old May 4, 2004 | 06:27 PM
SilverGTV8's Avatar
SilverGTV8
Actually 5-20 is used in almost all new ford cars. The oil is thinner and helps Ford meet CAFE requirements for fuel economy. For a while 5-20 wasn't avalible in a synthetic, 5-30 was.
I am just concerened with the protection, as the motor starts to create more heat. All be it, it won't be for a couple of years, but bad things happen when you change weights in a car that is used to something else, So I want to start with a weight that I should be using when it finally does make the numbers I want.
Old May 4, 2004 | 06:35 PM
MelloYello's Avatar
MelloYello
Id stick with what your using.. I love Royal Purple... and the 5-20 will be good for this summer
Old May 5, 2004 | 01:50 PM
LLADNAR's Avatar
LLADNAR
well actually ford does not recomend using anything but 5w20 in cars specified with it after 2001,, the only car/suv that doesn't use it is the 4.0 in the explorer(ohv) not sohc, but anyway if you put in thicker oil it will not get into all of the places that the 5w20 will because after 01 for started building their engines with tighter specs so thus the new oil. we have even looked here at work and the spec books show tighter clearences for 5w20 cars.
so stick with the 5w20
Old May 5, 2004 | 10:39 PM
VertStangGT86
OK, yea, disregard what I said above, for some reason I was thinking about 20-50 not 5-20, think it was a bit of dyslexia or something[8D]
Old May 6, 2004 | 12:27 AM
SilverGTV8's Avatar
SilverGTV8
Thanks for the input, ordering another case of 5-20 tomorrow!
mtgldr
Feb 3, 2024 09:00 PM
Dathan
Oct 5, 2015 05:52 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
lmurf60
Sep 24, 2015 10:07 PM
Sep 8, 2015 11:50 AM
