plugs continually fouling...
Old Jul 10, 2006 | 12:18 PM
stroker48's Avatar
stroker48
Default plugs continually fouling...
Fellow stang lovers,
new to this site and fairly new to driving mustangs.
Purchased a 83 mustang, 351W, runs strong but having problems after changing the 650 carb. that went bad to a Advenger 750 dbl pumper. Plugs fouling out after 3/4 days of driving? Founded that the 750 was dumping fuel in the back ports at idle after a few minutes of running so thought the fuel pressure might be to much. Added an inline fuel pressure guage, currently set at 6, ran ok for a couple of days but again, plugs seems to be fouling out as she is running raggely again.
Again, new to all this so any basic suggestions/ recommendations as a start [:@]?
Thanks,
Stroker48
Old Jul 10, 2006 | 12:36 PM
xzo6's Avatar
xzo6
Default RE: plugs continually fouling...
Has your 351W ever been rebuilt (1983).Do a compression test to see if all your cylinders are even.I would suggest that is a good place to start.
Old Jul 10, 2006 | 01:55 PM
GreyStang's Avatar
GreyStang
A 750cfm carb is kinda big for a 351W, unless you're revving the snot out of it all the time (ie drag racing a LOT etc)
Was the carb new? Floats & needle seals in good shape?
A highschool buddy was upgrading the carb on his highly modified '74 Trans Am 455ci bigblock, and the shop recommended only a 780cfm for that monster,,,
Old Jul 10, 2006 | 02:55 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Check the float levels, they may be high and adding too much fuel. Are you sure it's a 351? Make sure it had be transplanted in the past. How's your ignition system? Stock or modified. High or low mileage. Some details on the engine would be helpful.
BOB ROME
Jul 26, 2023 01:54 PM
cr620
Oct 3, 2022 10:18 PM
rgingo
Forum Issues and Feedback
Oct 21, 2015 12:49 PM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
