what carb?
Old Jul 13, 2006 | 06:27 PM
5IVE.OH's Avatar
5IVE.OH
Default what carb?
Alrighty, will the edelbrock 1406 model carb be a good one for my application? The engine mods are:
GT40P heads ported
Comp Roller rockers
not sure on cam specs was told it came out of a sprint car engine, I have a new crane cam powermax H-272-2 I could install, but am lacking a new set of lifters.
Weiand stealth intake (also have a weiand x-cellerator intake)
Long tube headers, flowmasters
3.73 gears
I have a holley 750 on it now but it looks like it came from a JY and the smell when you get on it makes your eyes burn.
What do you guys think? also what kinda numbers would a combo like this be roughly?
Old Jul 13, 2006 | 06:54 PM
myshifter's Avatar
myshifter
I ♥ Acer
Default RE: what carb?
650 holley or the 600 edel/carter (jet-up) will work, use the stealth intake. Need to know the cam to be able to give some kind of guesstimate. The 750 is running rich
Old Jul 13, 2006 | 07:16 PM
Sidewayz6.0's Avatar
Sidewayz6.0
I agree. 750 is too big. Holley 650 with mechanical secondaries would probably fit this application well.
Old Jul 13, 2006 | 08:21 PM
5IVE.OH's Avatar
5IVE.OH
Is there a way to figure what the cam specs are without taking it out of the car?
Old Jul 14, 2006 | 12:08 PM
Chopper's Avatar
Chopper
Crane has a website that should have this info.Or you could use a deree wheel and a dail indicator mounted so the indicator reads directly off the pushrods.Hydraulic lifters will bleed down under pressure so you might have to remove the rocker from the cylinder you are measuring to releive the spring pressure.Just mount the dial indicator so the plunger fits directly into the oil hole in the pushrod.
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sminemann
Sep 17, 2015 09:24 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
