Headlights
Old May 17, 2004 | 12:40 PM
Obsol3te's Avatar
Obsol3te
Default Headlights
Just bought new headlights recently and put them in.
Got em nice n straight looking now, but got something screwed up I think.
When it rains the driver side always fills with water now...
how in the hell is this one happening and how do i fix?
i have it setup EXACTLY like the passenger side one.
Old May 17, 2004 | 12:45 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: Headlights
The lenses arent cracked? Theirs also seals around where the replacements bulbs twist lock into place, make sure those are there and in good condition - or that you twisted them into place. That would be the only way water could get inside.
Old May 17, 2004 | 01:52 PM
Obsol3te's Avatar
Obsol3te
they are twisted in place
not cracked either
theyre BRAND NEW
bleh
any other ideas?
Old May 17, 2004 | 02:05 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
When their twisted in place its an enclosed space, theirs no other way for water to get in other than at the opening where you insert the bulb - or if the lense itself isnt sealed (like a crack). You may want to check again. You could always squirt water around the areas and see where its coming in.
Old May 17, 2004 | 02:33 PM
Obsol3te's Avatar
Obsol3te
k ill give the water thing a try
thx
Old May 17, 2004 | 03:38 PM
bmorrisj's Avatar
bmorrisj
or drill a small hole on the bottom of the lense....
Old May 17, 2004 | 04:29 PM
fantasyfords's Avatar
fantasyfords
Maybe they are liquid cooled? lol I drilled a hole in my pass side headlight. Works great.
Old May 17, 2004 | 04:35 PM
VertStangGT86's Avatar
VertStangGT86
A hole would probably work if you can't find why it's doing that. You could always pull it out and submerge it until just before the water could get into the bulb hole in the back and look for water coming in or turn it with that hole down and put it underwater completely and look for bubbles.
Old May 17, 2004 | 05:08 PM
Obsol3te's Avatar
Obsol3te
i drilled a hole on my winter beaters light, its all horridly yellow and horrible
dont really want that for my BRAND new lights that one seems to leak.
Old May 17, 2004 | 05:18 PM
VertStangGT86
Try the sumbergence thing, if you find a little leak get some silicone and seal it.
