Automatic Gears Question
I'm a lay man [noob] for automatic transmissions. I'm really confused on what my cars gears are for. I've got (D),3,2,1 in my car. What specifically do each of them accomplish, what gear ratio's are they configured for.
My friend advised me to try 3rd gear for drag racing, but results showed otherwise. He though that it created a higher transmission fluid pressure and was capable of shifting faster, a necessity.
Could anyone help me or redirect me to a topic? Thanks.
They should act the same. When you're at the strip, just leave it in D unless it's shifting into overdrive at the VERY end... if it's doing that, put it in 3 so it won't shift to overdrive at the very end.
All that switching between them does is prevent the transmission from shifting above that gear. If you put it in 2 and put the pedal to the floor, it'll shift through first, but it won't shift past second... you'll find yourself bouncing off the rev limiter if you just hold the pedal, it'll stay in second gear. Same goes for 1 and 3, they'll each keep it in first, or at most third respectively.
It does not change the fluid pressure or anything crazy like that. It just effects which gear the transmission will stop shifting at. As for the individual gear ratios, that varies per transmission and you will have to go look them up. In 4-speed automatics, 3rd gear is 1.0.
Ah, very helpful. Thank you.
For some reason, at the track, while I had it in 3rd gear the 2005 Mustang GT only ran a 11.6s on the 1/8. That's terrible. On the second run, I used Drive and ran a 10.6.. still not great. On the third run, I had the car brake-revved up before the start with a little tire spin and I finished with a 9.528s on the 1/8mile. So, I'm just curious as to why the third gear would run so slow? Do you think overdrive (4th gear) actually helped the last runs?
ORIGINAL: ShadowDrake
Unless the 05 GT doesnt have one, I've never looked.
Luke9222
Oct 22, 2015 11:55 PM
musnicki
Sep 23, 2015 07:11 AM
Sep 3, 2015 07:14 PM
