throttle body and smog question
Old May 20, 2004 | 09:56 PM
lift350's Avatar
lift350
Default throttle body and smog question
i just bought a 1995 gt with some motor work done. this is my first muscle car so i dont know much about mustangs. i went to get it smoged because this is a CA car and the said it wont pass because of the throttle body. the throttle body is a 70mm bbk is this smog legal? the also said the fuel evaporater canister is missing. where is this located on the car? the people i bought it from said it is on the car. also has high flow catalytic converters are these legal?
Old May 20, 2004 | 10:43 PM
Acer2428's Avatar
Acer2428
Site Mod
Default RE: throttle body and smog question
Yes......... I have no idea.........and Yes.
Sorry I can't be more help.
Old May 20, 2004 | 11:19 PM
white93 GT's Avatar
white93 GT
the fuelevaporater canister is in the front engine compartment in the very front on the passenger side. it has two tubes on the top. thats all i know
Old May 21, 2004 | 01:33 AM
lift350's Avatar
lift350
thank you for your help
Old May 21, 2004 | 02:31 PM
MelloYello's Avatar
MelloYello
I wouldnt think that 70mm would fail a smog test..... Unless your MAF just freaked out or something and sent more fuel in than needed..... But the throttle body should be fine.... Your cats should be ok too, what kind are they? High flow cats are usually still 50 state legal for smog testing..... the Canister is located at the front the engine towards the pass side or sometimes there down on the frame rail, it may be still there and the hoses arent hooked up, there will be a fuel line running out then a hose that runs to the CANP (its a smaller solenoid) then up to the intake manifold... So check the hoses...
Old May 21, 2004 | 02:52 PM
lift350's Avatar
lift350
they never tried to smog it, i took it there they opened the hood and did not see the canister so they said it will not pass without that. then they saw the tb and said they thought it might be race only. you said the canister could be on the frame rail, where on the frame rail? as for the converters i have no idea what kind they are.
Old May 22, 2004 | 02:28 AM
VertStangGT86's Avatar
VertStangGT86
I have a real question, what the hell does race only mean, it's so vauge and doesn't really seem to mean anything anymore. Just seems like something people say to sound smart. Same thing with "custom" that is supposed to mean just that, not a premade aftermarket part for your type of car. But anyways, just look for the canister (should be rectangular) down on the right side. I wouldn't worry about the cats, get the canister squared away and take it back and have them try the smog on it.
Old May 22, 2004 | 01:20 PM
Acer2428's Avatar
Acer2428
Site Mod
race only = off-road only = not street legal
Old May 22, 2004 | 02:04 PM
VertStangGT86
I know that I just mean people call way too many things race only that aren't really but are just performance.
Old May 22, 2004 | 07:48 PM
MelloYello's Avatar
MelloYello
If its on the frame rail itll be on pass side at the front.... And your throttle body should more than pass a test.... If you still have cats on the stang those should be fine also.... Guess you wont know till they test ya lol
Thats why I love NM no smog checks lol
If the canister is not on the frame either youll have to go pick one up at FOrd or a local parts store, while your at it look through a manual for your year of stang and it should give you picture diagrams so you have a better idea of what your looking for
Mello
