How detectable?????
Old May 26, 2004 | 11:12 PM
Monty's Avatar
Monty
Default How detectable?????
How detectable is a bent valve?
Can it make my car run like crap?
Ok. My timing chain broke. And after thinking about it i just put on a new one? Started it up and it ran like crap!
So I decided to pull the head. I did and everything looks great. I konw for sure one valve took a hit. It's on the number 8 cylinder. The piston has a minor ding on it?
The only prob is the valve looks good. Just a little discolored where it took the ding.
Can this cause it to run so crapy????
Old May 27, 2004 | 12:06 PM
WNDSOR's Avatar
WNDSOR
Default RE: How detectable?????
it would probably smoke if it was bad, do you have it in time? did you line up the gears right?
Old May 27, 2004 | 01:53 PM
LLADNAR's Avatar
LLADNAR
if a valve hit a piston you need to replace it,,no reason to tear down the motor see a questionable cheap part and not replace it,,,send the heads to a good head shop and have them looked over
Old Jun 2, 2004 | 10:59 AM
ShadowG03's Avatar
ShadowG03
I guess that's what you get for not doing scheduled MX, you're lucky you didn't punch a hole in your piston... which you should replace anyway, if you heat it up with a ding in it it could come apart inside your block and do some serious damage. You could have a bent valve and not even notice just by looking and NO it would neccesarily smoke if it is bent. Did you line up all the timing marks before installing the chain or just throw it on and hope for the best?
Old Jun 2, 2004 | 11:07 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
have you done a compression test yet? if the valve isnt sealing then it would show up on a compression test. no need for more speculation. if the compression isnt good on all the cylinders it would tell you that your valve timing is probably off, if just on that cylinder than you're valve timing is probably fine and you need to replace that valve.
Old Jun 2, 2004 | 01:28 PM
hunterzach_02's Avatar
hunterzach_02
you should also check the pushrods if u havent already
Old Jun 2, 2004 | 01:29 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
he's got a 4.6
Jb145700
Aug 21, 2022 06:37 AM
Urambo Tauro
Jun 10, 2016 03:28 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Editorchops
Oct 15, 2005 04:57 AM
