Front End Noise???
Old Aug 2, 2006 | 03:35 PM
beerman1378's Avatar
beerman1378
Default Front End Noise???
I recently noticed a squeaking noise coming from the front end and over the course of a few weeks it has gotten a little louder. When I'm stopped a turn to the right or left makes a sound like a bed squeaking. I had it on a lift and the tie rod/ends are tight. Maybe the Rack and pinion?? If so what might the problem be? Anyone else have this issue or have heard of anyone with this issue?
Rob......
Old Aug 2, 2006 | 11:48 PM
WhiteStang01's Avatar
WhiteStang01
Default RE: Front End Noise???
Yeah mine is doing that too, I think the rack bushings are worn but havent had time to lift the car and check underneath.
Old Aug 3, 2006 | 01:17 AM
mike s 95's Avatar
mike s 95
check your ball joints. they are probably dry . you cant lube them they need replaced (ford had a brighter idea)
Old Aug 3, 2006 | 01:22 AM
beerman1378
I am thinking it may be the rack bushings too. When I was underneath u could see the whole rack shifting.....and from a quick peek it sounded as if it were coming from the bushing area....
Old Aug 4, 2006 | 01:56 AM
NewMexMustang's Avatar
NewMexMustang
I had the same problem plus mine was popping when I would turn right. I took it in and there happened to be a tsb (technical service bulletin) out for that problem. What ford did to fix it was put a new steering bracket. Not sure if you have the same problem though if you are not having popping.
Old Aug 4, 2006 | 02:08 AM
98BlackCobra's Avatar
98BlackCobra
I have the same noise, just the squeeking... i checked my wheels to see if they have any play and i did notice i have a little play in my passenger balljoint.
Old Aug 4, 2006 | 04:59 AM
beerman1378
I have to put my car on the lift tomorrow and check it out. Its either the rack bushings or the ball joint. Thanks for the info guys
bjdutch2005
Mar 24, 2017 03:38 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Emblazoned
Sep 3, 2015 10:45 PM
