TRUE dual exhaust is...
Old Aug 5, 2006 | 06:15 AM
mikev08826's Avatar
mikev08826
I ♥ Acer
Default TRUE dual exhaust is...
Please explain your answer for post to mean anything...
Old Aug 5, 2006 | 06:42 AM
SilvrStang's Avatar
SilvrStang
Default RE: TRUE dual exhaust is...
Its two pipes, they can either be a side exhaust or a rear exhaust
http://v6stangs.com/articles/exhaust/trueduals.jpg
here is a picture explaining it little better
Old Aug 5, 2006 | 11:44 AM
BraMas's Avatar
BraMas
True duel is when 1 pipe comes of the Left bank of the engine and 1 pipe comes off the right bank and they both exit from any type of tail pipe in any position without being tied together with a Y pipe or any type of cross over pipe. Your poll makes no sense.
Old Aug 5, 2006 | 12:15 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: BraMas
You can have an X or a H pipe and still be true duals. The key is that they don't go into one single pipe and then back to two, (like on my SS) FWIW both types of systems can perfrom very well, if they are designed right .
Old Aug 5, 2006 | 05:45 PM
BraMas's Avatar
BraMas
Ya I was gonna put that in my first post but I figured it would confuse him.
Old Aug 6, 2006 | 03:07 AM
Stang9946's Avatar
Stang9946
Two seperate pipes from headers to tailpipe. Doesn't matter how they get there..straight back side by side down the same side of the car, side by side straight down the middle, etc....
Old Aug 6, 2006 | 04:59 AM
mikev08826's Avatar
mikev08826
I ♥ Acer
Nope...it's not a logic question...for if it was...ya'll be right
It's not 2 out of each side...
Answer is...
it originated from the 442...4 barell carb, 4 speed, 2 pipes from the same side
To the people who wrote..."as long as they don't connect..." good guess, and your logic makes sense, but your wrong.
just thought i'd enlighten.
Just another tidbit of info for everyone.
Old Aug 6, 2006 | 05:09 AM
OnyxCobra's Avatar
OnyxCobra
you can have dual exhaust and still have it come out one side, a good example of this was the new GTO.
Old Aug 6, 2006 | 11:55 AM
JD1969's Avatar
JD1969
ORIGINAL: mikev08826
Answer is...
OK buddy You have not enlightened anyone and this thread just seems like a way for you ***** posts. FWIW true duals have been around way longer than the Olds 442. 442 did mean what you said, but it in now way was the originator of the dual exhaust system.
Old Aug 6, 2006 | 12:07 PM
BraMas's Avatar
BraMas
SO this whole post was a question about what GM called there duel exhaust system on the 442? Thank you Mr. Obvious[sm=chairshot.gif]
Answer is...
[/quote]
