AFR Heads...
Old Aug 13, 2006 | 05:29 PM
gebasgt's Avatar
gebasgt
Default AFR Heads...
How much HP can I expect from just a swap out of my factory heads for some AFR heads?
Old Aug 13, 2006 | 05:36 PM
P Zero's Avatar
P Zero
Default RE: AFR Heads...
Depending on which afr's. But while youre tearing into the motor might as well put at least a B303 cam and some 1.72 rockers in it. BUt HP gain with 185's Id imagine at least 80HP witha tune.
-P.
Old Aug 13, 2006 | 11:07 PM
OnyxCobra's Avatar
OnyxCobra
I have been told with a mild 5.0 the AFR 165s will give you more power than the 185s.
Old Aug 20, 2006 | 07:49 PM
GetsLooseOnTheJuice's Avatar
GetsLooseOnTheJuice
ORIGINAL: gebasgt
the stock e7's are boat anchors. Peal that dead weight off and stick a set of afr-165's on that pony. Depending on the previous mods I would expect a healthy 50+hp gain. I'd definatley stick a cam in there while your at it. E303 is my choice for a nice street/strip machine. Make sure you tell your performance parts dealer your head/cam/rocker combo to get the properly sized *NEW* push-rods.
p.s.
Don't use the 185s they're too big.
Old Aug 20, 2006 | 11:49 PM
OnyxCobra's Avatar
OnyxCobra
AFR 185s also wont work with the stock bottom end b/c of piston to valve clearance problems...
95_GT_Stang
Dec 11, 2004 12:23 AM
Big5.0.13.7sec.
Sep 13, 2004 02:19 PM
87mustang347
Sep 5, 2004 11:13 PM
Milky
Feb 12, 2004 11:52 PM
lpstangman
Feb 11, 2004 12:07 PM
