Engine Light keeps flipping on...
Old Aug 14, 2006 | 03:31 PM
Gurndogg's Avatar
Gurndogg
Default Engine Light keeps flipping on...
My Engine lights keeps comming on and then turning off once a week. Has this happened to anyone else? What should I do?
Old Aug 14, 2006 | 03:33 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: Engine Light keeps flipping on...
I believe the 96 Mustang is OBDII compliant. When that light comes on again, go to an AutoZone and have them scan the ECU to see what code comes up. It's free.
It may be stored if it's come on and off a few times so you may be able to find out without the light on.
Old Aug 14, 2006 | 03:37 PM
samseed101's Avatar
samseed101
+1 on the free scan from AutoZone. Too many possibilities with too little information at this point.
Old Aug 14, 2006 | 03:50 PM
Gurndogg's Avatar
Gurndogg
Autozone said there computer isn't big enough for my vehicle. Thanks any other options>? What is OBII complient?
Old Aug 14, 2006 | 03:56 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: Gurndogg
wtf does that mean??
OBDII compliant means that it uses a standard set of codes to represent engine and emission related problems. These codes can be retrieved by using a Hand Held code reader that's widley available.
Prior to 1995 every manufacturer and in some cases every model of car had its own cryptic codes used to identify problems. Many times they were retrieved using morse code like blips from a dash light or LED on the ECU and no manufacturer used the same connector to plug a scanner in.
I would say your other option is to take it to Pep Boys and ask them to run the same scan. Depending on the service guys some may do it for free some may want to charge you. Or you could try a different AutoZone location. The one you talked to you doesn't seem to know what they're talking about.
Old Aug 14, 2006 | 05:08 PM
samseed101's Avatar
samseed101
yeah, I'm wondering wtf that means too. I think it's AutoZone Noob slang for "I don't know how to use the scanner so I'll feed you a BS line."
Maybe I'm wrong, but I thought hte whole point of OBDII was to standardize everything, thus making it universal.
Old Aug 17, 2006 | 12:34 AM
Crystal's Avatar
Crystal
We take our cars to Advance Auto for the free code scanning. So far, they have never been wrong. Hopefully, you only need to replace a sensor!
Old Aug 17, 2006 | 12:38 AM
Gurndogg's Avatar
Gurndogg
Thanks I will go to Advance Auto tomorrow.
Old Aug 17, 2006 | 12:45 AM
samseed101's Avatar
samseed101
ORIGINAL: Crystal
My first thought was O2 sensor (probably like a lean 176 code or something.) They seem to come and go and don't really seem to affect anything too badly (depending on the severity.) But again, there are just way too many possibilities.
djbigskrilla
Sep 20, 2022 01:04 AM
Scottyboy187
Nov 5, 2015 04:18 PM
J.casone400
Aug 28, 2015 09:33 PM
kevans79@yahoo.com
Aug 18, 2015 08:16 AM
drumhedd2005
Aug 13, 2015 09:59 AM
