Trouble shifting gears
Old Jun 18, 2004 | 10:33 AM
IMPORTDIS's Avatar
IMPORTDIS
Default Trouble shifting gears
About a week ago I had a really hard time shifting into all gears. The following day for some reason all was well, gears shifted actually smother for some reason. This morning driving to work for some reason it would not want to go into 1st, I actually had to turn off the car put into 1st and then turn on the car. Then 2nd and 3rd were a bitch to get into but 4th & 5th were very smooth. Does anyone know what the problem can be?
Thanks in advance
Jimmy
Old Jun 18, 2004 | 03:59 PM
e40water's Avatar
e40water
Default RE: Trouble shifting gears
what year is youre car? It sounds like to me you need youre clutch replaced, My friends car had the same trouble last week, Now it works like a charm. Good Luck
Old Jun 18, 2004 | 04:05 PM
IMPORTDIS's Avatar
IMPORTDIS
Hey e40water, it is an 86gt. Also another issue... [:@] now my turning signals are screwed up. Either left or right the turning signal stays on instead of blinking on or off. I check to see if any bulbs were out but they all seem to work???
Old Jun 18, 2004 | 10:07 PM
CDN_Rhino's Avatar
CDN_Rhino
I know what is wrong you have [sm=smiley15.gif] gremlins [sm=smiley15.gif] livin' in you car. Go to church and ask for an exorcism.
Oh well a hope you can get to the bottom of it before more sh!# happens.
GOOD LUCK
Old Jun 19, 2004 | 03:25 AM
e40water's Avatar
e40water
HAHA CDN Rhino, Ok Importdis right on youre drivers side under youre dash near youre fuse panel their should be a round greyish or clear big fuse Its called a flasher fuse that controls the blinking of youre turn signals, Just got to the parts store, and ask for a turn signal flasher, That should fix that trouble for ya.
Old Jun 19, 2004 | 06:57 PM
vfast's Avatar
vfast
I ♥ Acer
have you had the igintion switch ever replaced?
as for the shifting..try checking the oil in the trans...also look at the quadrant at the clutch pedal...a new clutch cable kit maybe be needed and if it is I have a 3 pcs adjustable one new in box from upr
Old Jun 20, 2004 | 03:00 PM
IMPORTDIS's Avatar
IMPORTDIS
I found the flasher and replaced; now blinkers are working again. Thanks e40water.
I also found an article online in regards to adjusting the clutch, fairly easy. Clutch feels so much better. Thanks all.
Jimmy
CS2007
Jun 25, 2019 09:45 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
Explosive
Oct 2, 2015 07:45 AM
