04 Mustang Drivers Side Window Wont Work
I have read several other posts regarding this issue with no definite answer. My drivers side power window is stuck in the closed position and will not go down. Passengers side works fine. Is there a seperate fuse for each door? Also, if it is a blown motor how hard is it to fix. This problem seems to be intermittent, one day working and then the next day its not. It always fails on the up postition. Hard to believe its the motor. Possibly the switch? Any commenst will help.
Thanks...
Thanks...
i have a problem some what like that, some times i can close the passegenr window all the way from the driver side i have to lean over and do it from its controller, let me know if u get an answer? ill do the same.
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
Mustang Sally72
Aug 11, 2015 07:54 AM
