engine flushing
Old Aug 22, 2006 | 01:21 PM
curtis817's Avatar
curtis817
Default engine flushing
Anybody ever used transmission fluid to flush the engine? My wife has a older accent with quite a bit of sludge buildup (at least what I can see under the oil filler cap).
Old Aug 22, 2006 | 03:05 PM
65coupe88hatch's Avatar
65coupe88hatch
Default RE: engine flushing
Never done it myself but according to documents the previous owner of my first car filled out he did it every 2 oil changes, car ran good so im going for it didnt mess anything up.
Old Aug 22, 2006 | 03:17 PM
curtis817's Avatar
curtis817
thanks for the reply, do you know how much he used?
Old Aug 22, 2006 | 03:27 PM
65coupe88hatch
it says that he used 2 quarts of Pennzoil Mercon Dexron III Auto Tranny Fluid.
Thats all i got on it, he noted the brand and 2 qts after every 2 oil changes
Old Aug 22, 2006 | 04:35 PM
curtis817's Avatar
curtis817
Thanks again, it is a tough call trying to decide to flush or not...
I have been reading alot of mixed reactions with engine oil flushing using different products to do it with. The last thing I want to do is make a real problem by trying to prevent one.
Old Aug 22, 2006 | 04:53 PM
65coupe88hatch
i hear you, after i got the car i never continued with the flushing. and dont do it in my stang.
Good luck hope all works out well.
Old Aug 22, 2006 | 05:40 PM
ncmurf00's Avatar
ncmurf00
On an older car with a lot of buildup...hmmm...sounds like a potential can of worms.
Tranny fluid contains a boat load of detergents which will really clean it up. I've heard this a thousand times, if you clean it too good, you'll end up leaking it.
My neighbor was a Ford Mechanic for 25+ years and would completely fill his engine with transmission with a new oil filter.
He'd drive on it for about a week, then change it back to regular oil (with a new filter again).
This has been done for as long as he's had the truck, and now has over 250,000 miles on it. Doesn't burn any oil and doesn't smoke.
Could be a good practice on a new vehicle, but I would just change the oil again after about a week to avoid new problems.
Old Aug 22, 2006 | 05:48 PM
65coupe88hatch
haha that may explain why that poor car of mine lasted to 263,000 before it died, im happy it got me around but man that car needed to die.
Nick Oliver
Oct 17, 2018 04:22 AM
Nov 18, 2015 01:34 PM
rksnow1
Sep 14, 2015 08:46 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
Sep 10, 2015 07:23 PM
