86 electric problems
Old Jun 21, 2004 | 03:42 PM
TRL12087's Avatar
TRL12087
Default 86 electric problems
i have an 86 GT and a few weeks ago i started having electrical problems. when i would give it gas the electric would dim. now its gotten worse to the point that the car stalls due to loss of power. Any guesses on what it might be?
Old Jun 21, 2004 | 03:49 PM
roundman's Avatar
roundman
Default RE: 86 electric problems
Sounds like the alternator has gone bad and the car is trying to run off the battery alone. Suggest you pull both the alternator and battery and take it to a parts store that can test both of them and tell you which one is bad.
Old Jun 21, 2004 | 04:20 PM
TRL12087's Avatar
TRL12087
ive already replaced both the battery and the alternator. it worked for a day or so then went back to the it was. i also replaced the solonoid but no luck. anything else?
Old Jun 21, 2004 | 04:55 PM
roundman's Avatar
roundman
When was the last time you did a tune-up and replaced the spark plug wires, plugs, distributor cap and rotor, etc? Need more info about the symptoms of the problem before I can suggest anything else.
Old Jun 22, 2004 | 05:06 PM
e40water's Avatar
e40water
Heya TRL12087 is youre car fuel injected or Carberated?
Old Jun 23, 2004 | 03:21 AM
TRL12087's Avatar
TRL12087
its the first year of the EFI
Old Jun 23, 2004 | 05:46 AM
e40water's Avatar
e40water
I would look into youre alternator and battery issues, If ya got EFI, Thats usually the first thing I would look at.
Old Jun 23, 2004 | 11:28 AM
TRL12087's Avatar
TRL12087
ive already replaced both. its even been to a mechanic and the guy couldnt find whats wrong with it. he found one wire on the harness that was a little cracked so he fixed that but it didnt help. the guy actually told me that he doesnt know and to bring it somewhere else.
Old Jun 23, 2004 | 01:36 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Just because you replaced them doesnt mean your charging system is working. Check to be sure you have 14~ volts at the battery when the car is running, and 12~ volts when the car is off.
Old Jul 1, 2004 | 02:38 AM
TRL12087's Avatar
TRL12087
wow, i dont really have any idea why but my stangs running again. it turned out that the solonoid i replaced was bad so i put the old one back in and it started right up and has been running strong since! a little wierd but im not complaining
