over drive explaination please
Old Aug 30, 2006 | 12:06 AM
Sean W.'s Avatar
Sean W.
Default RE: over drive explaination please
okay... i think i am starting to understand this, still got a still Qs though..
so is, " over drive " like a mod or a replacement for a transsmission. or is overdrive that is inside the transmission, or is over drive just a nother gear? im sorry if im asking so many questions, but i came here to learn..
Old Aug 30, 2006 | 12:10 AM
ShadowDrake's Avatar
ShadowDrake
Overdrive is just another gear... for modern transmissions, in manual transmissions, 4th gear is ALMOST always 1:1, and 5th and higher are "overdrive" gears (ratio of .65:1 or so). For the 4-speed autos in stangs, 3rd gear is 1:1, and 4th gear is your overdrive gear.
In newer transmissions, the overdrive speed(s) are typically as a result of combinations of planetary/epicyclic gearsets which are integrated in the transmission. In these cases, there is no separately identifiable "overdrive" unit. A number of such transmissions and transaxles are manufactured by Aisin, for use in vehicles produced by many different manufacturers.
You may also want to read here: Wikipedia on "overdrive"
Edit: Also, this may be good... howstuffworks.com on automatic transmissions
Nick Oliver
Oct 17, 2018 04:22 AM
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
StalkerGT
Sep 25, 2015 02:41 PM
dalefrancis88
Sep 11, 2015 07:15 AM
Sep 8, 2015 11:50 AM
