over drive explaination please
Old Aug 29, 2006 | 06:41 PM
Sean W.'s Avatar
Sean W.
Default over drive explaination please
hey fellas,
you know that song " Hot Rod Lincon " by Chralie Daniels
there is a part in the song that goes, " took my foot off the gas and man alive i shoved it down into over drive "
First ov all, let me ask you what " Over Drive " is.
secodly, why do you have to take your foot off and hit it hard? is that how you get into over drive?
Old Aug 29, 2006 | 06:44 PM
Twister's Avatar
Twister
Default RE: over drive explaination please
ok, an overdrive is a gear beyond the 1:1 gear...all trannys have a 1:1 gear ratio...where the driveshaft turns once for every revolution of the engine. On a T5, it is 4th. A transmission with an overdrive that allows the driveshaft to spin faster than the engine.
as for the song, he let off the throttle to shift.....
Old Aug 29, 2006 | 08:42 PM
dan's Avatar
dan
ORIGINAL: Twister
well put
Old Aug 29, 2006 | 09:17 PM
Sean W.'s Avatar
Sean W.
does every car have over drive?....
Old Aug 29, 2006 | 10:18 PM
Colorado_Mustang's Avatar
Colorado_Mustang
No. Only cars with OD transmissions.
ORIGINAL: Sean W.
Old Aug 29, 2006 | 10:53 PM
GreyStang's Avatar
GreyStang
Also, both automatic & manual trannies can have an overdrive gear, sometimes 2! like in some manual 6-speed trannies the top 2 gears can both be overdrive
Old Aug 29, 2006 | 10:55 PM
mustangman02232's Avatar
mustangman02232
ORIGINAL: GreyStang
yup, the cobras t56 is like that
Old Aug 29, 2006 | 10:57 PM
Sean W.'s Avatar
Sean W.
and what does over drive do? better performance? higher speed? what?
also, would i be able to put on one my classic 68' stang. if so, how much would one cost?
Old Aug 29, 2006 | 11:00 PM
samseed101's Avatar
samseed101
ORIGINAL: Sean W.
Think of it as a highway gear... Basically it allows you to maintain your speed (or increase your speed) with lower RPMs to the engine. So if you can go teh same speed or faster with lower RPMs, you are saving some $$$ on gas and give the engine a little rest. So when youre on the highway is a set of 4.10s, you're not keeping the tach in the red just to go 85 MPH Well, maybe not that bad, but you get the idea.
Old Aug 29, 2006 | 11:30 PM
Twister's Avatar
Twister
ORIGINAL: Sean W.
Better gas mileage, less wear and tear, and a swap can be as cheap as $1500....
