Gear Calculator??
Old Aug 30, 2006 | 12:46 AM
BlazeGT's Avatar
BlazeGT
Default Gear Calculator??
I remember seeing a gear calculator on the forums where you type in some numbers and it tells you what size gear you have...i tried the search function and could not find it. I would really appreciate it if someone could find it for me..im just making sure i have what i think i have because i dont want to get new gears and have it be the same. Thanks.
Old Aug 30, 2006 | 12:53 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: Gear Calculator??
RPM=(336*ratio*MPH)/TireDiam
Ratio is the current drive ratio combining the tranny and rear end ratios.
Old Aug 30, 2006 | 01:08 AM
BlazeGT's Avatar
BlazeGT
Yikes, all that was kindve confusing. At 2K RPMs in first im at 15 mph with stock tires (not sure of tire diameter, 17 inch rims with maybe four inches on either side??? dont really know) is there anyone that could tell me the rear end gears??
Old Aug 30, 2006 | 01:15 AM
BlazeGT's Avatar
BlazeGT
Actually...i think i found the calculator, but could someone give the gear ratios for a manual (t-5??) I think its a t5, its stock on a 94 gt. THanks.
Old Aug 30, 2006 | 04:15 PM
samseed101's Avatar
samseed101
You can figure it out using this calculator if you work backwards. Enter the tire size, enter the tranny, enter the speed, enter a gear (like 3.73) and see if the speed matches up with the RPMs for your particular setup. Then depending on the RPMs you cna change the gears up or down until they match. Should take less than 60 seconds to figure out what you have.
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
