Climate Control problem
Old Aug 31, 2006 | 12:43 AM
blaven's Avatar
blaven
Default Climate Control problem
Seems that my ac/vent/heat won't turn on for some reason. I just insalled a new headunit in place of the shaker 500 and it was working before that and after i installed the new HU. Now it won't turn on at all. Do you think i may have blown a fuse somehow? Everything else works fine its just the bottom 3 climate control buttons that won't do anything. I made sure they were connected back together about 20 times but still haven't had any luck finding out what the problem is.
Old Aug 31, 2006 | 01:10 AM
Anthonyandmarisol's Avatar
Anthonyandmarisol
Default RE: Climate Control problem
if you checked to make sure you didnt accidently unplug anything than i would check the fuses there are fuses under the dash and under the hood just incase you didnt know well i would try that
Old Aug 31, 2006 | 01:27 AM
blaven's Avatar
blaven
Yeah i suppose i'm going to have to pull the passenger side panel to check the fuses since i didn't see anything wrong with the ones under the hood [&:]
Old Aug 31, 2006 | 01:28 PM
blaven's Avatar
blaven
Dunno what was wrong but i pulled all the fuses and nothing was blown. So i took out my stereo and just plug'd in the climate control and it worked. Put my stereo back in and i went off again. Must have been a loose wire or the harness's not being all the way on but its fixed now
Art161
Sep 9, 2015 10:33 AM
Sep 8, 2015 11:50 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
M3hunter
Sep 5, 2015 03:42 PM
