Newbie needs help.
Old Sep 1, 2006 | 06:44 PM
blazinyellowbeast's Avatar
blazinyellowbeast
Default Newbie needs help.
Let's see, where to start. Well its started the other night (last sat), I left a softball tournament and the car was running fine, about 2 miles down the road (through town, 35 mph) the car started to run like crap. Around 2200 RPMs it would just shudder real bad and would almost stop pulling. I figured maybe a burnt wire, so I stopped and checked but didn't see anything. I was about 20 miles from home so I just drove it the rest of the way. It would cruise at 55 mph pretty much normal but if you tried to give any gas and it would shudder (kinda sounds like a helicopter), I didn't give it to much gas (for fear of tearing something up) but it seemed to clear up around 3000 RPM. Well I get it to a friend shop and leave it for the night, went back the next morning and she started up and ran fine. (I was thinking maybe some bad gas) But it done the same thing on the way home from work just now. Any one have a clue where I should start?
95 GT. 302 Ford Motorsports short block. Trick Flow twisted wedge heads, upper and lower intake. BBK Cold Air. 24lb Ford Injectors. BBK throttle body. MAF. BBK equal length headers. Offroad H Pipe. MSD cap rotor, and 6AL. Probably forgetting something.
Thanks.
Old Sep 2, 2006 | 06:06 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: Newbie needs help.
Sounds like a problem in the fuel system. Check the pressure and flow.
Old Sep 2, 2006 | 09:55 AM
corvetteguy's Avatar
corvetteguy
Have you put in a bottle of injector cleaner?
Old Sep 2, 2006 | 10:28 AM
Chopper's Avatar
Chopper
The MSD 6AL ignition box or the ignition module (if you still have one) might be a place to look.The symptoms point to an electrical problem that's heat related.As electrical faults get heated up they can expand and cause tiny cracks to open and interupt the flow of electrons.Computer chips and controllers can also fail and cause all kinds of apparently unrelated problems.
Old Sep 2, 2006 | 12:20 PM
lemonademaker's Avatar
lemonademaker
I'd say it was either some funky petrol or some water in your tank (again, making your gas all out of whack)
Old Sep 2, 2006 | 12:37 PM
blazinyellowbeast
Thanks for the help. I was kinda thinking it was an ignition problem, but wasn't sure. At least now I have somewhere to start. I'm not sure about the gas, the last time I filled up was at my usual place, but crazier stuff has happened. I'll throw some injector cleaner in it.
I unplugged the 6AL and ran it straight off the coil (Blaster) and it was doing the same thing. The car is back at my friends shop now, was going to start by changing the plugs and wires (maybe a couple months old), does anyone think this is a waste of time or a good place to start?
Thanks again.
Old Sep 2, 2006 | 03:27 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
It does sound like a ignition prob....more towards the distributor then the plugs/wires if they're only a few months old. Did you have any probs getting the rotor off when you put the msd one in there? Also check the fuel pressure just to cover all of your bases..
Thunderball
15
Nov 22, 2015 11:49 PM
Dathan
Oct 5, 2015 05:52 AM
NYstang
Sep 30, 2015 09:56 PM
mustangheaven
Sep 29, 2015 11:00 AM
