'67 Fuel Type?
Old Jul 28, 2006 | 05:53 PM
Foxrider64's Avatar
Foxrider64
Default '67 Fuel Type?
I just recently picked up a 1967 coupe as a project car. It is in running order and is drivable, but it is now out of gas. I have no idea as to what kind of fuel to use. Were the original mustangs still using leaded fuel? Or is it cool to use unleaded fuel. Also what octane is best for a 200ci 6 cylinder?
Thanks for your help.
Old Jul 28, 2006 | 06:04 PM
JDBullitt's Avatar
JDBullitt
Default RE: '67 Fuel Type?
I'm assuming your talking about a stock 289? Regular gas should be fine, if it does spark knock, just go up on the octane next time, or put some octane boost in it.
Old Jul 28, 2006 | 07:22 PM
Foxrider64's Avatar
Foxrider64
its not the 289. there were some other motor options besides the 289 as a straight 6. the smallest was a 170 that was only made for the 1964 models, and there were a couple others up to the 289. I believe they stopped making the 200's when they got past 1967 and used the 289's as the baseline motor. I could be wrong though.
but thanks for your input i dont want to fry the heads.
Old Jul 28, 2006 | 08:54 PM
xzo6's Avatar
xzo6
Back then lead was in the gas and it probably used 87 octane.The unleaded gas was good for the valves on cars built back then.I think unleaded came around 1974(forgive me a may be off by a few years).If that car has not had an engine replacement or had it rebuilt in 39 years why worry about it now.Likely someone has probably rebuilt it,changed the valves and so you are fine with 87 unleaded.
Old Aug 31, 2006 | 07:51 AM
kalebiscool's Avatar
kalebiscool
its not the valves you have to worry about, its the valve seats.as long as your not hard on the motor i would just run regular 87.i run 7000 rpm on 93 octane(only because of compression) with stock 1970 cast iron seats on a 306.as long as there is no valve bounce you should be fine.easy to toulip valves if you overrev on those seats though.
Old Sep 2, 2006 | 02:21 AM
I_AV8_4U's Avatar
I_AV8_4U
You can purchase a lead substitute at any auto parts store or Wal Mart. Just add to the tank at fill up. It keeps the valves/seats from burning. I use 87 oct in my '67 289.
Good luck,
Troy
Old Sep 2, 2006 | 10:37 AM
Chopper's Avatar
Chopper
I drove a 70 Old's Cutlass on 92 unleaded for years.Fairly hard too!The valve seats were OK when I had to get the valves replaced due to a timing gear explosion.
You should be fine but If you're still concerned the hardened valve seats aren't that expensive to install (I don't think?)
Old Sep 2, 2006 | 03:31 PM
Colorado_Mustang's Avatar
Colorado_Mustang
289 is a V8, not a 6. The 250 was the biggest 6 put in the cars, 71-73 mainly. The 300 six was put in light duty pickups and the like.
ORIGINAL: Foxrider64
kevsgt
Oct 9, 2015 10:12 PM
Sixx
Oct 5, 2015 07:36 PM
svfetter
Oct 5, 2015 11:39 AM
guitarman376
Sep 30, 2015 05:54 PM
mrappe
Sep 26, 2015 10:16 AM
