line locks???
Old Jul 2, 2004 | 05:16 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Default RE: line locks???
OK, a line lock will lock the front brakes of a car, and allow the rears to be released, thus making a burnout easier to do and alittle easier on the car, they can be used on both auto and manual transmissions. Rollin, to do a burn out without a line lock in a stick shift car, roll through the water (pay attention to the water box guy, he will guide you) when givin the ok, put the trans in 2nd gear and rev up the engine to about 4500 rpm and dump the clutch, the tires will start to spin, now this is the hard part, you must quickly move your left foot onto the break pedal and apply enough break to keep the car from lurching, while you floor the gas. The tires will now go up in smoke It's easy with alittle practice
Old Jul 2, 2004 | 05:21 PM
drumaz's Avatar
drumaz
that sounds like a helluva lotta fun!!!! Why 2nd gear?
Old Jul 2, 2004 | 05:33 PM
fast83gt's Avatar
fast83gt
Thanks JD1969 for the line lock info. I love learning ne things.
Old Jul 2, 2004 | 05:38 PM
JD1969's Avatar
JD1969
ORIGINAL: drumaz
After rolling through the water the tires will spin very easy, 2nd gear spins them faster than 1st, thus putting more heat in the tires faster and at a lower engine rpm. In my auto I start in 2nd and shift into third. In a stick shift I don't bother trying to shift (although I can) it's to much to do all at once and 2nd works just fine.
Old Jul 2, 2004 | 06:25 PM
horatio102's Avatar
horatio102
ORIGINAL: JD1969
that's exactly how I left a pair of stripes up one block, around a corner, and down another 1/2 block. I'm sure I will need new rear shoes soon.
Old Jul 2, 2004 | 06:42 PM
vfast's Avatar
vfast
I ♥ Acer
to do those impressive burn out you can inject water to ground right in front on the rear tires..I used my windshield resv. to pump water and on the street I spray a lil traction additive....car hooks really well then
Old Jul 2, 2004 | 07:13 PM
NOS/MAN's Avatar
NOS/MAN
I ♥ Acer
ORIGINAL: RollinThunder
ORIGINAL: NOS/MAN
I SEE YOU GOT A STD TRANS LIKE ME... I JUST ROLL THOUGH THE WATER PUT BUT IN SEC. GEAR PO CLUTCH HOLD BRAKE TELL CARS BOGGS OR FT WHELL COME OFF GROUND,,THATS WHEN I NOW THERE HOT...IT TAKES SOME SKILL BUT YOU WILL GET IT AT FIRST I WAS SLIDDING SIDEWAYS ON MY BURN OUTS BUT AFTER FEW TRYS I WAS A PRO AT IT ,,I NEED NO LINE LOCK,
I have no idea what u just said lolol....cuz someone else tell me how to do a burnout to heat up my tires b4 I make my run??...thanks
,,,YOU GO TO CSHOOL RIGHT???JUST READ IT ..AGAIN ,,2ND GEAR CAUSE IF NOT YOU GOT TO SHIFT AND I KNOW YOU CANT TIPIE TOE...SO FORGET IT,,,,,,JUST GET THE LINE LOCK...GO 100 AND HIT IT...HAHAHA.
Old Jul 3, 2004 | 02:42 PM
Sidewayz6.0's Avatar
Sidewayz6.0
I can't believe nobody asked this, but are you running slicks or street tires?
Old Jul 3, 2004 | 11:58 PM
RollinThunder's Avatar
RollinThunder
I'm running street/slicks....and nos/man what the hell ?? r u drunk bro lolol ...and I kno this is kind of an obvious question but JD1 wont dumping my clutch 4500rpm take a big tole on clutch??
and also how long should I sit there spinning? how do I kno when the tires dont need anymore heatin up?
Old Jul 4, 2004 | 03:12 AM
bossman351's Avatar
bossman351
I got a line lock on mine with a two step wired in and this is how it goes. After pulling through the water box hold the burnout button then pump your brake pedal to build pressure. Dump the clutch and hold it to the floor ( my car cuts out at 2500 with the two step). Have a crew mwmber or friend on the track with you to let you know when they are warm then release the button ( this is my favorite part) and hold it to the floor and roast em. After that, if you got a friend with you have his squirt some VHT in front of your rear tires then tell you when to roll em over. After that you stage and go. Simple.
