Airbag code 12 ???
Old Sep 7, 2006 | 10:33 PM
sarahsmustang's Avatar
sarahsmustang
Default Airbag code 12 ???
Yesterday, I finished putting the 95 vert back together. (front end wreck). Part of the job included replacing both crash sensors, both airbags, the clock spring and the airbag module under the console.
The airbag light on the dash cluster comes on and flashes once then pauses then flashes twice = code 12 ???
It does this about three or four times, then it stays on.
Any ideas?
The only other thing I'm waiting on is the second replacement hood. Bought one on EBAY from a guy in IL. he wrapped a refridgerator box around it. What an idiot. It arrived with more damage then the hood on the car. I bought another yesterday, it's ridding on our company truck back to me from N.C.
tas
Old Sep 8, 2006 | 11:40 AM
ToplessGT's Avatar
ToplessGT
Default RE: Airbag code 12 ???
well, when my airbags popped off, I never did replace them. I popped the airbag warning dummy light out, but then the damn thing would beep at me. So, I put the lightbulb back in, and it blinks like yours does, but stays on. Maybe you dont have something connected right? I dont have a code book which would tell you what the problem is. Maybe call autozone or something like that, they usually have something. Good luck
Old Sep 8, 2006 | 11:48 AM
sarahsmustang
It's amazing what can be found on Google.
http://www.veryuseful.com/mustang/te...95.html#CODE12
Old Sep 8, 2006 | 12:09 PM
ToplessGT's Avatar
ToplessGT
wow, that is some good info. If I ever put airbags back in (well, that work anyway), I'll have to keep this webpage
Old Sep 8, 2006 | 12:35 PM
sarahsmustang
I just replaced the blown 10a airbag fuse. Now I have a code 52
tas
Old Sep 8, 2006 | 12:41 PM
sarahsmustang
Someone over at V6 just posted this, how to clear the codes!
http://www.veryuseful.com/mustang/te...agCodeClearing
Old Sep 8, 2006 | 01:27 PM
sarahsmustang
That couldn't have been an easier!
Located the grey plug under the glove box (right under the edge of the dash), turned key to run, after the code flashed for the first time, I jumped the two wires in the grey plug, after 5 seconds, the airbag sensor beeped, removed jumper, turned key off, and all is well.
tas
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
mustangheaven
Sep 29, 2015 11:00 AM
