boost problem
Old Sep 11, 2006 | 10:20 PM
Anthonyandmarisol's Avatar
Anthonyandmarisol
Default RE: boost problem
that sounds like its your problem, and if its a turbo that will cause a pressure drop, fix your exhuast leak, wheres your exhuast leak at? try looking at the hose coming from the manifold into the turbo check it right at the ehaust manifold check that hose thats probly what it is let me know
Old Sep 13, 2006 | 01:30 AM
chirp_5957's Avatar
chirp_5957
another thing that i noticed...as you keep the turbo kicked in i will lose boost PSI
i know diddle squat about turbos...is this normal..or not..
Old Sep 13, 2006 | 02:13 AM
turbostang21's Avatar
turbostang21
^^^no....just check all the bolts from the exhaust manifold to the head, manifold to turbo (turbine housing), turbo to downpipe. also look/feel around the manifold and the turbine housing for any cracks...it's pretty common in stock cast manifolds/old turbine housings. you will see black exaust suit around the area of the leak
Old Sep 13, 2006 | 03:04 AM
chirp_5957's Avatar
chirp_5957
i can check all these without removing anything right?
Old Sep 13, 2006 | 05:13 PM
turbostang21
you might have to remove a heat shield to get at the manifold but nothing serious....come on man just go out there and do it[&o] git er done
Old Sep 13, 2006 | 05:34 PM
7upedition's Avatar
7upedition
yea... git er dun...... start at the bock and follows the exhaust system/turbo and check every joint for a loose bolt and retighten everything.... do the same with the intake
Galactic
Apr 29, 2019 02:56 PM
Oct 7, 2015 07:02 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
angeljoelv
SVT Forums
Sep 10, 2015 09:12 PM
