Eaton Differential
Old Jul 9, 2004 | 02:06 PM
90GT347's Avatar
90GT347
Default Eaton Differential
I recently through a ring gear bolt around in my rear end little to my knowledge. So, I have decided to put an eaton posi-traction differential in, and was wandering if anyone knew where i could get one on discount. Any help or insight to my problem would be appreciated.
Old Jul 9, 2004 | 02:59 PM
roundman's Avatar
roundman
Default RE: Eaton Differential
Try www.holcombmotorsports.com, they might be able to help you out.
Old Jul 9, 2004 | 03:22 PM
90GT347's Avatar
90GT347
I have been looking in to finding a rear differential. But, I am not sure which is the best to go with for my dollar. Most people I have talked to say Eaton, Eaton, Eaton. But, I am not totally sure and I wouldn't be objectional to an Auburn or maybe even something else. If someone has some insight on a good rear end diff. please help.
Old Jul 9, 2004 | 03:25 PM
roundman's Avatar
roundman
I had an Auburn diff in my '88 while it was a street/strip car and it worked fine for me both on the street and at the track with a set of 3.73 rear gears. I only got rid of it when I went with a new 9" Ford rear with a spool and 4.56 gears.
Old Jul 9, 2004 | 07:08 PM
vfast's Avatar
vfast
I ♥ Acer
well first you want to make sure it is rebuildable as some aren't..you could go with a truck posi which has 31 spline and you can rebuilt the disk pack and to tighten it up more use 1 or 2 of the best of the old ones(disks) and insert them with the new pack but not beside each other
Old Jul 11, 2004 | 12:29 PM
roundman's Avatar
roundman
if you go with the truck diff, you will need to get some 31 spline axles as the stock Stang axles are 28 spline.
Old Jul 11, 2004 | 05:19 PM
mkspeed26's Avatar
mkspeed26
im pretty sure summit and jegs have a good selection of rear ends.
also, anyone have any experience with the eaton e-locker. it sounds cool and i might think about putting one in my car.
Old Jul 11, 2004 | 10:19 PM
vfast's Avatar
vfast
I ♥ Acer
yes..r/man..but I thought he would upgrade to them anyway..as most of us do..
Old Jul 12, 2004 | 12:33 AM
skylark494's Avatar
skylark494
Got one in my 'lark. 9" 31 spline moser axles 3.50 gears. Put it in in '99 when I blew the stock rear. Don't drive it as much since I joined the Navy in 2000. Very strong.
mtgldr
Feb 3, 2024 09:00 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
UrS4
Oct 3, 2015 06:23 AM
KingRando
Oct 2, 2015 08:06 AM
Sep 16, 2015 07:53 PM
