TPS adjustment?
Old Sep 16, 2006 | 09:21 PM
StangMan1010's Avatar
StangMan1010
Default TPS adjustment?
i noticed whenever my car is idleing..the car wants to shut off..the rpm goes down very low..however when i throw the car back in reverse or drive, the RPM serges up to 1500 than drops back all the down to about 5-600 rpm and begins to shake...
i got the codes read at my nearest autozone and the code said that the car was running to lean on bank 1 and 2.
i am thinking it could be a TPS adjustment problem...any ideas? thanks.
oh and by the way..i gave it a full tune up..spark plus and all the good stuff...recently got a new EGR valve...
Old Sep 16, 2006 | 09:37 PM
Chopper's Avatar
Chopper
Default RE: TPS adjustment?
Clean the MAF element with alcohol or electrical contact cleaner.BE CAREFUL those things are fragile.You could also have a vacuum leak somewhere in one of the hoses that run off the intake tube.If that doesn't help out try cleaning the IAC valve.You can slip the straw from a can of carb cleaner between the hose and throttle body, and with the engine warmed up and running,spray the carb cleaner into the hose.This will cause the engine to stumble and kick but will do a pretty good job of cleaning the IAC.You can also take it off and clean it or replacement is always an option.
Old Sep 16, 2006 | 09:45 PM
StangMan1010
already did that...i cleaned the MAF with carb cleaner..nothing...ill try the IAC...but, could the TPS be the culprit also?
thanks for ur time.
Old Sep 17, 2006 | 12:13 PM
MBDiagMan's Avatar
MBDiagMan
When you make such a post, you need to offer as much and as COMPLETE information as possible.
Exactly what year model and engine are you working with? Exactly what were the code(s?)
Have you hooked up a vacuum gauge yet? If so what did you find?
Many Ford TPS are not adjustable, thus it would be nice to know year and engine. Is it safe to assume that this is a Mustang?
Old Sep 17, 2006 | 04:22 PM
StangMan1010
no, even tho i do own a mustang lol...
its a 98 lincoln navigator, 5.4L V8 with about 82000 miles on it.
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
