Symptoms
Old Sep 18, 2006 | 05:35 PM
65coupe88hatch's Avatar
65coupe88hatch
Default Symptoms
How would you know if you had an exhaust leak? Im about 75% positive but i wanted to see if there were any other ways to look for it.
Old Sep 18, 2006 | 06:18 PM
OnyxCobra's Avatar
OnyxCobra
Default RE: Symptoms
usually you can hear a hissing or ticking kinda noise, also sometimes you can smell exhaust inside the car when you're stopped.
Old Sep 18, 2006 | 06:22 PM
65coupe88hatch
ticking...yes, smell it yea but only if i left off going down a hill.
Old Sep 18, 2006 | 07:04 PM
DG03's Avatar
DG03
Look for condensation coming out of it,
Especially in the morning, for the first start up!
Old Sep 18, 2006 | 07:54 PM
Poobs's Avatar
Poobs
It is not easy to do but if you can get two willing victims U can have them place the bottom of their shoe sole on the exaust pipe tip while you peek under the car.
We did that in the shop a couple of times but the guys wore thick leather work boots.
Obviously the idea is to try to block the exaust so it comes out of the leak area. You will see a stream of smoke from the leak or maybe even hear a hissng sound.
Another way is with an exaust analyser but who has that ?
The area around the leak also gets discolored and may even drip water from condensation so keep looking....
Old Sep 18, 2006 | 10:25 PM
DG03's Avatar
DG03
Yep
Old Sep 19, 2006 | 03:58 PM
65coupe88hatch
Ok ill try to check it before i leave for school tomorrow morning.
Old Sep 29, 2006 | 10:56 AM
65coupe88hatch
Im still drawing a blank on finding it. I know it isnt after the cat since its all new and the sound seems to be coming from above the cat. Im not seeing any carbon on the outside of the pipe but i can hear it and smell it... right before the cat there seems to be 2 dips on the pipe (top and bottom) im assuming from fitting the pipes to the cat can that be the problem?
Old Sep 29, 2006 | 05:08 PM
Chopper's Avatar
Chopper
You can find exhaust leaks by stuffing rags into one side of the exhaust and throwing a couple of smoke bombs in the pipe,then stuffing rags into the open side.Then you just look to see where the smoke comes out.
Old Sep 29, 2006 | 05:19 PM
Poobs's Avatar
Poobs
I like that!!! Even better than my method
Meystang
Sep 25, 2015 04:05 PM
TfcCDR
Sep 14, 2015 12:08 PM
CarrieS
Sep 1, 2015 01:00 PM
sammyd16
Aug 30, 2015 10:03 PM
