Problem w/ throttle
Old Sep 20, 2006 | 08:38 PM
Nittro22's Avatar
Nittro22
Default Problem w/ throttle
Whenever the gas pedal is pressed there is a rattling noise. The noise is present only when the pedal is depressed and only while the vehicle is in motion. Does anyone have any idea as to what it could be?
Old Sep 20, 2006 | 11:06 PM
threeg502's Avatar
threeg502
Default RE: Problem w/ throttle
Hi how are you? Since you have to be driving and pushing the gas it seems to be related to engine load. You might be pinging or detonatng. That's caused by timing which is too far advanced. Anymore info might help. Does it sound like its in the front or rear of the car etc.?
Old Sep 20, 2006 | 11:21 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Some more details on your car would be good. Is it stock, which engine, etc.
Old Sep 21, 2006 | 12:55 AM
FoxGT's Avatar
FoxGT
Got any heat shields on your exhaust?
Old Sep 21, 2006 | 10:08 AM
Nittro22's Avatar
Nittro22
The car has aftermarket plugs, wires, headers, no cats, straigt pipes, CAI, performance tuner. The rattle sounds like it is coming from the drivers side of the engine, and is especially noticible if you throttle the car hard. Although when you look under the hood nothing seems to be loose, but the valves are not running as smooth as they should so i dont know if those are causing the rattle while driving.
Old Sep 21, 2006 | 10:11 AM
P Zero's Avatar
P Zero
What octane gas are you runnin. Id try runnin some premium in it and see if it goes away.
-P.
Old Sep 21, 2006 | 01:56 PM
Nittro22's Avatar
Nittro22
i am running 89. I have an SCT Tuner for the car and that was programed to run on 89 octane
Old Sep 21, 2006 | 07:37 PM
FoxGT's Avatar
FoxGT
Does it do it in first gear?
Old Sep 22, 2006 | 02:18 AM
Nittro22's Avatar
Nittro22
Yes. It does it whenever the vehicle is in motion and the gas pedal is depressed.
Old Sep 22, 2006 | 06:07 PM
trefilov22's Avatar
trefilov22
Broken motor mount?
