taillight problem
Old Sep 26, 2006 | 12:35 AM
Allstar's Avatar
Allstar
Default taillight problem
ok so my brake lights wont illuminate when i step on the brake but my runnign lights do turn on so the bulbs cant be dead because they light up when the running lights are turned on and off.. i checked the fuses under the drivers side dash and there all fine what can my problem be?
Old Sep 26, 2006 | 10:09 AM
corvetteguy's Avatar
corvetteguy
Default RE: taillight problem
The running (parking) lites are not related
to the brake lites other than the use the
SAME BULB. The bulb #1147 #1154 or
other is a dual fillament and either one
or both can burn out.
Take out the bulb and look at the fillaments.
Check the brake pedal switch.
Check the turn sig and hazzards.
Old Sep 26, 2006 | 10:13 AM
P Zero's Avatar
P Zero
Bulbs are bad. It cant hurt to replace em, theyre only like $1.98 for 2. Thats the first place Id start.
-P.
Old Sep 26, 2006 | 10:41 AM
threeg502's Avatar
threeg502
On my 86 GT I had a similar problem. I changed the switch, and while I was changing it I found the wires going to the switch were broken off from the movement of the switch over time. Check the wires right at the brake switch for breakage.
Old Sep 26, 2006 | 11:16 AM
FoxGT's Avatar
FoxGT
ORIGINAL: threeg502
+1
that doesn't make much sense why both brake lights would go bad at the same time. I think your problem is with the switch.
Old Sep 27, 2006 | 12:22 AM
Allstar's Avatar
Allstar
i will check that thank you guys
Old Sep 27, 2006 | 03:57 AM
Allstar's Avatar
Allstar
haha yeah thank you guys i fixed it, it was the switch under by the brake pedal the wire was pulled out a little so i pushed it in hit the brakes and it worked, man i love easy fixes like that
thanks again guys!!!
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 25, 2015 06:48 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
SilverStallion05
Sep 5, 2015 10:48 AM
