Stroker Engine
Old Jul 18, 2004 | 06:07 PM
Emosupside's Avatar
Emosupside
Default Stroker Engine
Im not very well educated when it comes to engines and I wanted to know how a 347 stroker engine works and how much horsepower it produces. where can I get a kit to convert my 95 302 to a 347 and will it be a big improvement. Thanks for all your responses.
Aaron
Old Jul 18, 2004 | 06:26 PM
callmecobra's Avatar
callmecobra
Default RE: Stroker Engine
it works by increasing the stroke by adding a bigger crank, longer rods, and shorter pistons. there is no set hp that it produces. to many variables.
Old Jul 18, 2004 | 06:30 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
The generally accepted rule of thumb on a NA engine is 1 hp for every cube added, although like nomo said it could come out to be more or less than that depending on alot of things. If your heads can't flow well enough to fill the extra cubes your not gonna benefit as much from stroking, on the other hand with a great setup or a power adder you will get more than 1hp per cube.
Old Jul 18, 2004 | 10:37 PM
OneGearhead's Avatar
OneGearhead
for it to be "converted", youll need to take your block to a machine shop, have it bored out, put the new internals in, put the top half of your engine back on THAT block, reinstall it in your car, etc, etc. if you get a stroker though......like MD said, if you dont have good heads, you wont make the hp youre lookin for. for who to go to, check out www.dssracing.com and check out www.coasthigh.com. DSS is supposed to be good, but, ive heard more good things about CHP than i have DSS. your choice. but, youll have to pay for the labor and the stroker kit itself, so, be ready to dish out a nice chunk of change when you do it !
Old Jul 19, 2004 | 11:56 AM
Mustang88LXKid's Avatar
Mustang88LXKid
unless he can rebuild the engine himself but it doesnt sound like because he said hes not that educated on stroker kits. Getting the block done for stroker kit can cost over 1000 dollars. some of those DSS shortblocks are good though new block, etc.
Old Jul 19, 2004 | 04:08 PM
619socalstang's Avatar
619socalstang
stroking a motor is not cheap. look for a short block and youll save;.
Old Jul 19, 2004 | 05:00 PM
Emosupside's Avatar
Emosupside
What would be a better investment , a stroker kit or a supercharger ?
Thanks
Old Jul 19, 2004 | 05:18 PM
vfast's Avatar
vfast
I ♥ Acer
well your talking..apple and oranges now.....
Old Jul 19, 2004 | 05:25 PM
callmecobra
ORIGINAL: Emosupside
Thanks
well obviously forced induction is the biggest way of making power, but like vfast said, its apples to oranges
Old Jul 19, 2004 | 05:30 PM
619socalstang
if your motro needs a rebuild then a stroke is the way you want to go, if it runs strong then FI it but either way youll need some good heads.
