Leaner or Richer and why?
Old Sep 28, 2006 | 03:39 PM
Stang9946's Avatar
Stang9946
Default Leaner or Richer and why?
Ok what's the differences and which is better? I was told that when you lean your car in that it cuts off fuel to the motor, it'll run hotter and it'll give better performance and power. Is this true?
Old Sep 28, 2006 | 03:57 PM
amrcnidyot's Avatar
amrcnidyot
Default RE: Leaner or Richer and why?
i thought both were bad...?? but i have no clue.
Old Sep 28, 2006 | 03:59 PM
Stang9946's Avatar
Stang9946
ORIGINAL: amrcnidyot
Well if your car is running too rich then you have to lean it in.....if it's too lean then you have to richen it up. You don't want too lean or too rich I know that much.
Old Sep 28, 2006 | 04:01 PM
amrcnidyot's Avatar
amrcnidyot
ohhhhh so your askin wich one would be better to be a little higher. like a little bit more lean or a little bit more rich. gotcha. cant help ya there
Old Sep 28, 2006 | 04:51 PM
corvetteguy's Avatar
corvetteguy
too lean and you burn your valves.
too rich and you carbonize them.
just right and your motor will be happy.
Old Sep 28, 2006 | 10:34 PM
Colorado_Mustang's Avatar
Colorado_Mustang
A little to the rich side is the safer of the two errors.
Old Sep 28, 2006 | 10:41 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
One is just as bad as the other, if taken to an extreme. Like Colorado said though, it is safer to be a tad rich than lean. Going lean can lead to detonation.
BlackBetty
Jul 23, 2021 08:48 PM
Stang9946
Jun 26, 2007 04:29 PM
jimnibob33
Oct 2, 2006 11:15 PM
RJM02GTDrag
21
Dec 21, 2005 11:13 PM
Tims 88GT
May 30, 2005 11:19 PM
