removing rear seats
Old Oct 4, 2006 | 12:27 AM
arkesh24's Avatar
arkesh24
Default removing rear seats
Can anyone please give me intructions on how to remove the rear seats of my 99 cobra convertible. In a way that I could put them back if I ever wanted to.
Old Oct 4, 2006 | 12:55 AM
AXLE's Avatar
AXLE
Default RE: removing rear seats
i have a coupe and dont know if their the same but if your directly behind the the front seat on either side their is a little button type thing you push thats right were the seat ends and the carpet starts. push that in and lift up, do this on both sides. and the bottom part lifts off. and for the back support their are screws you have to remove. once you find those buttons, should only take like 5 min. tops to remove the whole thing.
Old Oct 5, 2006 | 02:15 PM
ByPopularDemand's Avatar
ByPopularDemand
bump I need this on top so I have a reference when I try...Did it work
Old Oct 5, 2006 | 04:13 PM
amrcnidyot's Avatar
amrcnidyot
it should work exactly the same. go out to your car and wiggle the seat around and put a screwdriver or something under it and move it around untill you feel the switch. should be about a 1/4 the way in towards the middle on each side. when you find it push in on it "push towards the trunk" and wiggle the seat around then repeat on the other side and it should come right out
Dragonus18
Sep 9, 2015 01:21 AM
v8sn95
Sep 7, 2015 10:17 AM
Doogie65
Sep 6, 2015 02:55 PM
cbird1177711
Sep 2, 2015 08:51 PM
Sep 1, 2015 08:16 PM
