Standard or Automatic?
Old Oct 7, 2006 | 12:22 PM
Nub's Avatar
Nub
Default Standard or Automatic?
What do you feel is the better way to go for Street racing?
Also, if you could recomend a tranny based on a 351W motor and racing from a stand still.
Currently using a C5 Tranny with 3.54 gear in the rear. B&M shifter
I personally was thinking that Standard would be the way to go since you can better manipulate the RPM upon start, though I have no raec experience.
Old Oct 7, 2006 | 03:41 PM
RCT06GT's Avatar
RCT06GT
Default RE: Standard or Automatic?
I'm not the most knowledgeable poster when it comes to tranny's but I could tell you from experience that manual transmissions are much better for street racing IMO.
Old Oct 7, 2006 | 03:46 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
The only way I would suggest an Auto trans would be for high power drag racers. When you need that consistant "stall" launch. For streets, nothin beats holdin 1st or 2nd and stompin on it.
Old Oct 8, 2006 | 05:07 PM
Colorado_Mustang's Avatar
Colorado_Mustang
An auto with a stall will work very well with a high torque engine. A manual can be tricky and hard to learn, but it is easier to modulate the power to the wheels.
Which you choose will depend on your experience. Unless you intend to spend some time practicing a manual, stick with an auto like the C6 or C4.
Old Oct 8, 2006 | 09:03 PM
MuscleOwnzRice's Avatar
MuscleOwnzRice
if your going serious power, go with a auto and get torque converter and some other junk which will cost you an arm and a leg. But for just street use and all which is what you want, get an auto. It would take all that junk to get a stock auto into manual territory.....so IMO stick with a manny
Old Oct 14, 2006 | 03:24 AM
jonesracing2006`'s Avatar
jonesracing2006`
Try this before you get a new tranny,get a 3000 stall converter,manual valve body,line lock,4.10 gears youll be snaping your neck back...and really you dont even need the line lock ...
Old Oct 14, 2006 | 11:06 AM
Nub's Avatar
Nub
I currently have a C4 Tranny with a pretty high converter in it atm, or so it seems. What is the HP this tranny is capable to handle?
Also, what is considered Serious HP that would warrent moving to a Standard.
I have little to no experience in Launching but look forward to practicing!
Old Oct 14, 2006 | 01:31 PM
5IVE.OH's Avatar
5IVE.OH
A 351W will eat a T-5. Your auto is a much better trans to use. The only thing standards are good for is impressing high school kids.
b8checker
Oct 8, 2015 12:55 PM
guitarman376
Sep 30, 2015 05:54 PM
b8checker
Sep 30, 2015 07:11 AM
wraith777
Sep 28, 2015 10:49 AM
