351W ignition engine misses
Old Oct 10, 2006 | 03:11 AM
ericknope's Avatar
ericknope
Default 351W ignition engine misses
I have a 68 Mustang with a later model 351W engine recently rebuilt. The engine ran fine, all of a sudden it wouldn't start unless I give it some pedal, it runs extremely rough like its only running off 4 cylinders, when I release the pedal it dies. It is getting spark and fuel.
1. I recently welded on the the frame to replace floor pans, would this affect the Mallory Electronic Ignition?
2. Could it be running too rich or lean?
3. It has a edelbrock 650 carb and edelbrock intake, not sure if its dual plane or not. The fuel filter is clean but could the fuel pump not be supplying enough fuel.
Any suggestion would be appreciated.
Thanks in advance,
Eric
Old Oct 10, 2006 | 02:35 PM
SVTBill's Avatar
SVTBill
Default RE: 351W ignition engine misses
clean your carb, run high test gas, maybe some gum out....it sounds like fuel for sure. new plugs if you dont have them, something along those lines
Old Oct 10, 2006 | 04:01 PM
ericknope's Avatar
ericknope
yea the guy i bought it from said i needed to run higher octane fuel in it. i put 89 in it and it probably needs 93 with the higher compression, thats probably what is going on. should i drain the tank and replace all the fuel or just add octane booster? what does an engine normally do if i did indeed us too low of an octane fuel?
thanks,
Old Oct 10, 2006 | 11:41 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Lower octane won't cause the problems you're describing.
If you didn't disconnect the ignition box before welding on the car, there is a good chance you damaged it.
First thing to check would be to make sure there isn't anything in your carb blocking fuel flow. A piece of gasket can easily cause the problems you're describing.
Old Oct 11, 2006 | 12:55 AM
ericknope's Avatar
ericknope
You ain't gona' believe this; yet you probably will. You know what they say its always the easiest solution. I drained the tank, put 93 octane in it, changed the spark plugs, and PRESTO it runs like a champ. It was just strange to me that "she" quite running all of a sudden... Anyway thanks for all you guys help. It's a awsome feeling knowing that there a people out there who can offer great advice and bounce ideas off of!
Thanks again, until next time,
Nick Oliver
Oct 17, 2018 04:22 AM
Granatelli Sales
Mar 25, 2016 08:01 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
Sep 1, 2015 08:16 PM
