Carbs
Old Oct 13, 2006 | 06:42 PM
Vanilla822's Avatar
Vanilla822
Default Carbs
Is a 750cfm holley carb too much for a 302?? I was told a 600 would work better??
Old Oct 13, 2006 | 07:28 PM
5IVE.OH's Avatar
5IVE.OH
Default RE: Carbs
stock 302? yes.
Old Oct 13, 2006 | 07:37 PM
randy78045's Avatar
randy78045
Default RE: Carbs
Bigger carbs dont necessarily make more power... you have to be able to burn the fuel or wash your cylinder walls down with gas which isnt a good thing.... To give you an idea, im running a 650 on my engine... see below...
Old Oct 13, 2006 | 07:49 PM
P Zero's Avatar
P Zero
Default RE: Carbs
700 is about the most youd ever wanna put on a 302, and that would have to be one hell of a beast in order burn that much gas.
For a mostly stock 302 a 600 is about the best.
-P.
Old Oct 14, 2006 | 11:19 AM
Vanilla822's Avatar
Vanilla822
Default RE: Carbs
Yes!!! Well, you guys helped me get one problem figured out. When You first take off, the car seems to bogg down a little at first. I assumed the carb needed tuned. I was telling a buddy of mine and he said it's probably due to the amount of fuels it's dumping.
Old Oct 14, 2006 | 04:44 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: Carbs
A 750 won't bog a 302 because of the amount of fuel...they can be leaned out to get the right fuel/air mixture. The bogging is a result of a loss of air velocity due to the oversize bores. Basically, the air velocity drops and the fuel can't stay in suspension. The reverse is also true. A 600 can be tuned to provide as much fuel to the engine as a 750.
For a 302, you need to be turning serious rpm's to use up a 750...8500 rpm, give or take. A 600 provides enough air to achieve 6800 rpm or so (both depending on the efficiency of the heads, cam, intake). A 500 is great for a stock 302, but a 600 is pretty much optimum on a mild 302.
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sminemann
Sep 17, 2015 09:24 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
