View Poll Results: A poll
Premium(92ish) - Stock
27.27%
Mid-Grade(89ish) - Stock
13.64%
Regular(87ish) - Stock
9.09%
Premium(92ish) - Modified
50.00%
Mid-Grade(89ish) - Modified
0%
Regular(87ish) - Modified
0%
Voters: 22. You may not vote on this poll
What Octane Gas?
Old Jul 29, 2004 | 11:31 PM
FoxGT's Avatar
FoxGT
Default RE: What Octane Gas?
Just something for you all to check out next time you're at a hardware, chemical, ect... store. http://www.vtr.org/maintain/gasoline-octane.html
Is anyone able to find these at these prices? I've found Xylene at Lowes Hardware, but it was $9.97/gal
Old Jul 30, 2004 | 12:08 AM
Guest
Guest
Posts: n/a
premium for me!! damned 10.2:1 compression.
and i'm slow too. lol
Old Jul 30, 2004 | 12:14 AM
jdaniel's Avatar
jdaniel
I ♥ Acer
LOL AT 2000Si!!!!
There are guys at my track that throws 117 octane in their stock rides and Im just waiting to see one blow up going down the 1/4. LOL
Old Jul 30, 2004 | 01:02 AM
bobby's Avatar
bobby
i run 94, it burns cleaner if u have ignition mods, why would it blow up? LOL obsolete SLIGHTLY MODED!!! lol
Old Jul 30, 2004 | 03:19 AM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Higher octane will not make a car blow up, it will ruin your O2 sensors, if it is leaded. A givin engine will make peak power with an octane that just keeps the car from detonation, any higher and you are really just waisting money. Now there are oxygenated fuels such as Rocket Brand 100 octane, these types of fuel will make slightly more power when they are fresh, unfortunatly if not stored properly they loose the oxygenation and are then the same as any other fuel of a givin octane rating. Here is a good read on octane I can give the link of the full article if anyone is interested, it gets a bit geeky but is a good read if you like this sort of thing.
6.13 Can higher octane fuels give me more power?
On modern engines with sophisticated engine management systems, the engine
can operate efficiently on fuels of a wider range of octane rating, but there
remains an optimum octane for the engine under specific driving conditions.
Older cars without such systems are more restricted in their choice of fuel,
as the engine can not automatically adjust to accommodate lower octane fuel.
Because knock is so destructive, owners of older cars must use fuel that will
not knock under the most demanding conditions they encounter, and must
continue to use that fuel, even if they only occasionally require the octane.
If you are already using the proper octane fuel, you will not obtain more
power from higher octane fuels. The engine will be already operating at
optimum settings, and a higher octane should have no effect on the management
system. Your driveability and fuel economy will remain the same. The higher
octane fuel costs more, so you are just throwing money away. If you are
already using a fuel with an octane rating slightly below the optimum, then
using a higher octane fuel will cause the engine management system to move to
the optimum settings, possibly resulting in both increased power and improved
fuel economy. You may be able to change octanes between seasons ( reduce
octane in winter ) to obtain the most cost-effective fuel without loss of
driveability.
Once you have identified the fuel that keeps the engine at optimum settings,
there is no advantage in moving to an even higher octane fuel. The
manufacturer's recommendation is conservative, so you may be able to
carefully reduce the fuel octane. The penalty for getting it badly wrong,
and not realising that you have, could be expensive engine damage.
Old Jul 30, 2004 | 03:31 AM
Guest
Guest
Posts: n/a
nice write up thing... JD... but they don't sell leaded gasoline. You can buy a lead additive though.
Old Jul 30, 2004 | 03:38 AM
JD1969's Avatar
JD1969
I can buy leaded gas at my local Gas City right out of the pump,it does say it is "not for highway use" though, it's only 6 miles from my house, I can also get it from the speed shop in drums, any gas over 105 octane will have some lead in it (I think it could be 108).
Old Jul 30, 2004 | 04:16 AM
luckythirteen13's Avatar
luckythirteen13
87 octane. works fine for me
Old Jul 30, 2004 | 04:46 AM
Guest
Guest
Posts: n/a
ORIGINAL: JD1969
ok fine, just bcause your city is weird doesn't mean they sell it everywhere. lol It's not widespread, how about that?
Old Jul 30, 2004 | 12:12 PM
JD1969's Avatar
JD1969
Hey you calling Chicago weird?I don't really know about buying it at pumps in other cities, but anybody can order it in 55 gallon drums, I know Detriot sells it at the pumps.
