tranny -- aod
Old Oct 18, 2006 | 02:58 PM
slo5.0's Avatar
slo5.0
Default tranny -- aod
i have an 89 lx 5.0 w/aod.i occasionally like to shift it manually. under wot my tranny will hold off the 2 to 3 shift until about 5200rpm, but otherwise it jumps to 3 sooner than i think it should. is this something i could change by having a shifter with the ability to hold second and third gear shifts? my shifter like most i think, have 1,then D, then OD. i have a b@m shift kit in the trnny.(don't know if this matters for this situation) thanks
Old Oct 18, 2006 | 05:28 PM
Archion's Avatar
Archion
Default RE: tranny -- aod
I would have a Trans shop check the TV adjustment, adjust it by pressures, basically set your shift points.
Old Oct 18, 2006 | 06:54 PM
samseed101's Avatar
samseed101
That sounds normal for the AOD trannys. They tend to quickly jump through 2nd and go straight to 3rd. That's why when peopel shift manually with an AOD, they have to do the 1-D-1 shuffle.
Thankfully, I have an AODE tranny with a shift kit, so I can go 1-2-D.
Old Oct 20, 2006 | 12:19 PM
slo5.0's Avatar
slo5.0
so, based on the info provided a different shifter will not change the behavior of my aod??!!
Old Oct 20, 2006 | 01:17 PM
Archion's Avatar
Archion
Reworked pressures and a shift kit are your best bet. But a shifter would be good also, just for controllability.
treesloth
Sep 28, 2015 07:03 AM
2poor4u2
Sep 26, 2015 11:08 AM
prophotog
Sep 15, 2015 08:38 AM
jaiidutch
Sep 14, 2015 10:29 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
