99-04 seats wiring?
That really doesnt explain much. sorry but it would be much easier if you could tell me like what colors go where and in as much detail as you can bc im real Slow to catching on to things haha. thank you
Okay, this is really basic:
Look at the connector on the right side of the picture. This should be firmly attached to your seat. If not, note the orientation of the connector in the picture with the snap on the top. Attach a wire to each connector on the bottom, then twist them together and crimp on a blue female blade connector. (On the seat I used, the seat has "bullet" style connectors and I had to solder my wires to them.) Then attach another wire to the upper left connector and attach a blue female blade connector to it. Then plug the two blade connectors to the connector on your floor. If the power functions work properly, you're done. If everything works backwards, reverse the two wires on your connector. You can leave the fourth wire on the seat connector attached to nothing.
Now you're done.
Now you're done.
Wow! thanks alot. bc right now ijust have my old seat rail on the new seat and i have the switch kinda halfassed held in there so i can move up,down,front,back. and thanks to you i might actually have a proper functioning seat.
jwog666
Dec 27, 2021 08:09 PM
GT350 S550 Tech
Sep 29, 2015 03:29 PM
