Help - confused over ignition wire hype
Old Oct 24, 2006 | 06:37 PM
Poobs's Avatar
Poobs
Default Help - confused over ignition wire hype
Well, it looks like I,m in the market for a good set of ignition wires but there is a lot of crap out there[X(]
Found that one of my ignition wires measured 2.61 million ohms !!!!! [:@]
I found it because I decided to install a set of standard Autolote plugs to see if there was any change compared to the split fires ( 16k miles ) I had been keeping an eye on plug color, gas mileage and noticing an unburnt fuel odor when idling.
Back to the wires........ while the other wires mesure a few thosusnd ohms each depending on how long they are, the one wire is way high. I suspect it may cause part of the stuff I have been noticing.
I'm not an expert but know enough to be dangerous so when I see the claims made by wires manufacturers I get somewhat confused.
There are plenty of replacememnt wire sets out there - Autozone, Advance auto etc. all seem to tbe silicone supression wire bla, bla good as or better than OEM
The question is: What do I gain if I go to something like a Ford Motor Sports wire set as opposed to an OEM one ?
thanks
Old Oct 24, 2006 | 10:09 PM
Poobs's Avatar
Poobs
Default RE: Help - confused over ignition wire hype
Well, I found this, http://www.magnecor.com/magnecor1/frequent.htm
seems like good to share it
Old Oct 25, 2006 | 07:19 PM
Poobs's Avatar
Poobs
I picked up a set of Ford Racing 9mm wires.
I'm not expecting magic results from these but just that they don't screw up anything with RFI and that they last for a while.
Anybody have any expereince with these ?
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
marc954
Sep 29, 2015 03:05 PM
mrappe
Sep 26, 2015 10:16 AM
