f-150 tranny question
Old Nov 1, 2006 | 08:51 PM
Hung Like a Stang's Avatar
Hung Like a Stang
Default f-150 tranny question
what trannys will fit on a 93 f-150 4x4?
it has a t-5 that needs replacing now.
would a c6 or an aod fit?
any other 5 speeds?
thanks
Old Nov 1, 2006 | 10:48 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: f-150 tranny question
Any tranny with an output shaft and tailhousing meant to mate to that transfer case. I'm assuming you have a Windsor...
Old Nov 2, 2006 | 12:03 AM
Hung Like a Stang
i'm not familiar with ford tranny's. Do different trannys have different tailshaft lenghts like gm trannys? Or is every C6 or a t-5 the same? What would be required and how would I know?
Old Nov 2, 2006 | 12:53 AM
85lebaront2's Avatar
85lebaront2
Since you have a 4X4, you need a 4X4 transmission. Your transfer case is attached to the back of your transmission. The 4X4 transmissions don't have the regular output shaft and extension housing, they have a short output shaft and an adapter that mates up to the transfer case. You might try Ford Truck Enthusiasts http://www.ford-trucks.com you should be able to get plenty of information there. Good luck with it!
chrisdbassplayer
Oct 13, 2015 06:53 PM
treesloth
Sep 28, 2015 07:03 AM
2poor4u2
Sep 26, 2015 11:08 AM
jaiidutch
Sep 14, 2015 10:29 AM
