starter
Old Nov 1, 2006 | 10:08 PM
jason_sc_29650's Avatar
jason_sc_29650
Default starter
i have a 94 mustang gt all stock, and when i start my car the strater keep on turning over
what wrong
Old Nov 2, 2006 | 12:30 PM
Poobs's Avatar
Poobs
Default RE: starter
My best guest would be the solenoid on the starter....
Old Nov 2, 2006 | 02:27 PM
Archion's Avatar
Archion
Default RE: starter
+1 The onboard solenoid is sticking, the usual cause is prolonged exposure to low batt voltage and the contact points are burned in. Have your battery tested as well.
Old Nov 2, 2006 | 11:42 PM
DKGreenMetallic98's Avatar
DKGreenMetallic98
Default RE: starter
I've seen this problem on late 80's fords. replace the solenoid and you'll be good to go. but do it quick, so you don't bone your starter. then you'll be out $80.
Old Nov 3, 2006 | 01:44 PM
beheivjer's Avatar
beheivjer
Default RE: starter
i have also seen the ignition sticking just barely in the on position enough to cause it to run
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
logan409
Sep 26, 2015 07:43 PM
jaiidutch
Sep 14, 2015 10:29 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
daytooday
Sep 1, 2015 09:33 AM
