Starter trouble....
Old Nov 3, 2006 | 04:30 AM
SlvRgT's Avatar
SlvRgT
Default Starter trouble....
I beleive my starter has gone bad or maybe the solenoid...whats the best way to fix this problem...and is there a website or something that could help me do this in the garage without having to pay $$$ to a crooked mechanic...the car beigins to start but all fails and then that annoying clicking sound...thx for the feedback...keep stanging...oh yeah b4 i forget...i have moisture in my taillight...whats the best way to get it out...thx guys...and girls
Old Nov 3, 2006 | 11:44 AM
Chopper's Avatar
Chopper
Default RE: Starter trouble....
If the engine is starting to turn but then quits and the solenoid starts clicking that's usually a weak battery or a bad connection somewhere.
Try getting a jump start from someone,if the engine still starts to spin but stops and clicks then it could be the solenoid or the connections on the starter.This is where it gets interesting.
To remove the starter and solenoid you need lots of extensions to be able to get to the top starter mounting bolt.Go in from the front and use patience.Keep hammers and other things that can be used as a weapon out of sight until you finish.
Old Nov 3, 2006 | 12:05 PM
Archion's Avatar
Archion
+1
I keep a large tool of some sort for intimidation factor hanginging on the wall so the car behaves itself...lol
Old Nov 3, 2006 | 01:16 PM
ponysnake99's Avatar
ponysnake99
check the seals and grommets around each of the lights/bulbs for any cracks or something, if u find anything im sure a silicone sealant should work...someone else may have an easier cure...
as for your startin problem...i left u a short break down of a starter removal in your other post...hope it helps
Old Nov 3, 2006 | 01:40 PM
beheivjer's Avatar
beheivjer
nothing wrong with the starter its a power issue. either bad cables or weak battery. follow the cables flexing them slightly and if you feel a soft spot the wires are corroded and broke
Old Nov 3, 2006 | 05:29 PM
SlvRgT's Avatar
SlvRgT
when i jump start its perfectly fine and running...however if i go to the store and then try to turn it on again it wont...now if i run it for a while like drive 25 miles its will turn on...but barley...like somethings not holdin the charge...also i have a foglight wire that got shredded from rubbin on my tire...could that be an issue???....thx chopper
ORIGINAL: Chopper
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
logan409
Sep 26, 2015 07:43 PM
jaiidutch
Sep 14, 2015 10:29 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
daytooday
Sep 1, 2015 09:33 AM
