vibration when braking...
Old Nov 4, 2006 | 08:46 PM
tuneskies's Avatar
tuneskies
Default vibration when braking...
What can cause vibration when breaking? It doesnt happen at first, but if i break long enough it starts to vibrate the whole car violently. Still stops good though...[:@]
Old Nov 4, 2006 | 09:35 PM
wythors's Avatar
wythors
Default RE: vibration when braking...
Most likely your front brake rotors are warped, or possibly your rear drums. This is a fairly simple fix of either having the rotors machined smooth or just replacing them. Either way, put in a fresh set of pads at the same time. If the problem is in the rear, the same idea applies. Machine or replace the drums and install a new set of shoes. Fords are pretty notorious for warping the front rotors. I replaced mine with cross-drilled and slotted rotors many years ago and haven't had a problem since.
Old Nov 4, 2006 | 09:51 PM
SXGT's Avatar
SXGT
when your brakes are hot and they get wet they warp
Old Nov 5, 2006 | 10:03 AM
corvetteguy's Avatar
corvetteguy
Had the same problem with the GMC Savanah van.
I thought the rotors were warped because I did
not turn them with the last pad replacement.
Turns out there was a crack in the rotor
that expands with heat . In either case
it is time to replace the rotors.
Old Nov 5, 2006 | 12:54 PM
RonnieD's Avatar
RonnieD
I had this problem not too long ago. I rotated my tires and it fixed my problem. The guy said that my struts were bad, which what caused the premature wear on the outside of my front tires. But when i had the better tires up front, the vibration was gone. Does it vibrate at all when youre in higher speeds? even when not on the brakes?
Old Nov 5, 2006 | 03:30 PM
tuneskies's Avatar
tuneskies
No only when braking. I almost bet that it is warped roters... Thanks for the input!
mtgldr
Feb 3, 2024 09:00 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
mdj89
Sep 23, 2015 08:49 AM
ccdguy
Sep 19, 2015 05:20 PM
