Prestone Flush and Fill
Old Nov 6, 2006 | 01:37 AM
shando98's Avatar
shando98
Default Prestone Flush and Fill
1st: I'm a newb
2nd: I used the search function and came up short
3rd: I drive a 91 lx 5.0 AOD with some bolt-ons, intake, headers, exhaust, etc.
I was looking at my coolant and it definately had some rust in it. I drained it from the radiator drain on the lower passenger side. I filled it back up with water twice and let it drain until the fluid coming out was clear. I'm going to use some prestone super flush to clean it up a bit before adding my coolant.
While I was buying the coolant I bought the Prestone Flush and Fill kit. I've never used one and I have no idea where to look for the hose that I'm supposed to splice into. Has anyone used this kit before, and if so were you pleased? Can anyone point me to the right hose?
Old Nov 6, 2006 | 09:34 AM
corvetteguy's Avatar
corvetteguy
Default RE: Prestone Flush and Fill
The flush kits fit in one of the heater
hoses. That go to the firewall.
What I like to do to flush out the old
stuff is open the radiator top and bottom
and add a running garden hose while the
car is running.
The flush kit is a little more effecient
and faster.
Good luck.
Do not make the hose pressure at all
very high.
Old Nov 6, 2006 | 07:05 PM
shando98's Avatar
shando98
using this picture (ripped off from 5IVE.OH) as a reference where should I install the T-fitting at?
ORIGINAL: 5IVE.OH
Thanks!
4cylinderplus2
Oct 9, 2020 07:45 PM
wraith777
Sep 28, 2015 10:49 AM
GLOCKer
Sep 28, 2015 07:36 AM
foxdude
Sep 24, 2015 08:45 PM
zachary1988
Sep 4, 2015 03:04 PM
