ugh, bad mechanics make me mad
RE: ugh, bad mechanics make me mad
ask any decent mechanic and they will say that gears are extremely tricky to set up correctly. you mess up either way and you will have problems, they have to be perfect. and if they are new gears, you probably shouldnt have been romping on your car, they need at least 200 miles break in, and then change the fluid check/reset if necessary.
i work in a body shop and i never weld or even cut with a battery hooked up
i really like how they warned me of that. and no the body shop didnt do the rear end work, he has a guy come in from another shop intown that does that. just lately i have been not impressed at all with the shops work.
i work in a shop. i installed a set of gears uh matter of fact yesterdee. i just took the whole rearend off. Took out my welder and hammer and just welded and hammered them sumbitchs right in. Works like a charm
Yeah rear ends are touchy. Thank god they dont take too long though, thats the good part. And if you have done a few they get easier. Im just not sure what you meant when you said you pushed in the clutch and youre rear end stopped making noise?
ORIGINAL: tyybo
hah, maybe i should have you come up to North Dakota and teach that damn mechanic how to put in gears right..
North Dakota? Say it ain't so! Where bouts? I don't envy you spending 6 months on snow
