Removing Emblems....
Old Nov 7, 2006 | 05:22 PM
203Mach1ne's Avatar
203Mach1ne
Default Removing Emblems....
I just tried a search on this but didn't find a good answer
I want to remove my FORD emblem on the rear and my side emblems (ponies with flag in background) from my 2003 Mach 1, because I think it will look a lot sleeker
Can I remove these easily with a blowdryer (glued on) or will they leave a hole???
Old Nov 7, 2006 | 06:30 PM
godminus1's Avatar
godminus1
Default RE: Removing Emblems....
I'm pretty sure that your side emblems will have a hole, and I believe your rear emblem is just glued.
Old Nov 7, 2006 | 06:38 PM
203Mach1ne's Avatar
203Mach1ne
that's what the thread in the search implied...
but if I want to remove the side one, what can I do about the hole?
Old Nov 7, 2006 | 09:03 PM
SXGT's Avatar
SXGT
ORIGINAL: and1bbaii7
its only big enough to stick a pecil through , maybe just bondo the back side of it.
Old Nov 7, 2006 | 09:34 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
no u dont just bondo it will rust back thru! it will either need to be welded and then filled of u can grind the area down and fiberglass it, or u can use metal to metal but all these way are gonna require the fender to be blended
Old Nov 7, 2006 | 09:35 PM
203Mach1ne's Avatar
203Mach1ne
sounds good..
when I do remove the emblem, what should I use to remove the adhesive?
Old Nov 7, 2006 | 09:43 PM
penceman's Avatar
penceman
Stick a V-Tech badge over the hole
Old Nov 7, 2006 | 10:50 PM
Deleted User's Avatar
Deleted User
I ♥ Acer
Default [Deleted]
[Deleted by Admins]
Old Nov 8, 2006 | 03:34 AM
chris01gt's Avatar
chris01gt
Can anyone conferm this??? BEcasue I want to remove mine
Old Nov 8, 2006 | 05:01 AM
SXGT's Avatar
SXGT
ORIGINAL: chris01gt
iam pretty sure its NOT glued, if i remeber right , they sell colored ones on Ebay and they take 2 small screws? i cant confirm this, but ill go look it up
This emblem comes with adhesive on the back with two small prongs.
good finds....
http://search.ebay.com/ford-emblem-m...tZQ2d1QQfgtpZ1
